Braking by itself
Re: Braking by itself
Postby knobby1 » Wed Jun 04, 2025 8:06 pm
mr_miyagi wrote:Yeah I've managed to find that one. The wire connector on the end of the loom wires where the fornt brake pad wear sensor wire plugs in. Where they plug together on the side of the strut. The wire had broke off the pin right where it goes into the connector. I hadn't spotted it when I was fitting the new pads. It must've been badly corroded but was still in there, probably hanging on for dear life by just one strand. Trouble is it's broke right at the back of the pin on the loom side of the connector not the pad side. At least I've found it.
Just connect the two pad wear loom wires together and cut the wires from the pads off...this will have the light off, they're a closed loop system so when the pads wear down far enough, the wire wears through and opens the "loop", the light comes on...why we need a "pad wear" warning light is a mystery....only takes a couple of minutes to check pad wear at each service and replace as necessary....this seems to have worked for the last 50 years or so.
Postby gt_addict » Wed Jun 04, 2025 8:12 pm
Check the rear one too. on a FWD its clipped to the rear beam.
Hopefully that'll sort it but who knows. Report back though for future reference.
gt_addict
Postby mr_miyagi » Fri Jun 06, 2025 7:43 am
Ok so I've got the Forscan light app on my phone and I have a code.
C1B00:08-2B Steering angle sensor
Additional fault symptom - Bus signal/message failures
So I've fitted a new steering rack and not yet had chance to take it for the wheel alignement to be done, been too busy trying to sort out other problems. When driving in a straight line the steering wheel's about 5 degrees to the left.
I'm guessing once the wheel alignement is sorted the steering wheel sensor will need calibrating, is this correct?
mr_miyagi
