MartinP86 wrote:My van is the FWD version. If i'm not mistaken you also think that the pump may be on it's way out?
tranmx2 wrote:MartinP86 wrote:My van is the FWD version. If i'm not mistaken you also think that the pump may be on it's way out?
No mention re' pump being worn.
MartinP86 wrote:tranmx2 wrote:MartinP86 wrote:My van is the FWD version. If i'm not mistaken you also think that the pump may be on it's way out?
May have been a misunderstanding from my side, apologies for that.
I'll check the vacuum hoses for as far as i can see them/gain acces to them without taking half the van apart. To clarify, in short the issue seems to be that the engine needs more RPM to accelerate to build up enough vacuum and to have the hard pedals and the proper throttle response. Haven't had a look yet at the cost of a new vacuum pump yet but since driving off with a higher RPM seems to be the "solution" i hope it's not something expensive.
Reading my opening post again i wish i could edit it. Though English is not my native tongue (as a Dutchman) i could've described the problem much better than i did there, again sorry for that.
knobby1 wrote:
Throttle has nothing to do with vacuum...it's a "fly-by-wire" system and is electronic. Vacuum only affects brakes and heater controls, (if you have A/C fitted).
MartinP86 wrote:knobby1 wrote:That's why i think it's an RPM related vacuum issue, not throttle related in that regard aside from the fact that it'll have a weak throttle response when it doesn't have enough vacuum built up.
Low vacuum doesn't help the turbocharger, for starters. I know that. Now that i think of it, if low vacuum is weakening the throttle response AND making the clutch and brake pedals feel softer, it probably is the vacuum pump itself. Otherwise it wouldn't be in both "systems" i gues.
metalworker0 wrote:Well i wish you good luck hunting for a non rusty, low miles one, that isn't an ecoblue. so up to mid 2016
