fabcal wrote:I found the codes but they're partly unreadable. This one is the most readable but symbols on the rhs are wiped out.
Although I can't read the complete codes it is clear that the programmed codes are wrong.
1. Can wrong codes explain why I'm unable to complete the pump read?
2. What do I do with unreadable codes? Do I have to replace the injectors? No previous owner has written down the codes, that I'm sure of.
fabcal wrote:Yes but as I said I'm unable to read them because they are partly erased.
So I have to replace all the injectors, right?
fabcal wrote:The codes are wrong so yes it looks like the injectors have been replaced and not coded.
Is leak-off done with tubes and bottles connected at the top of the injectors and just running the engine idle? A picture of the setup would be very appreciated.
fabcal wrote:Could anybody help explain what the loose cable is?
fabcal wrote:I don't know if I have A/C but ok thanks.
Correct, it is LHD.
fabcal wrote:Are you saying it's possible to get my old injectors refurbished, i.e. get correction factors for them?
Users browsing this forum: Google Adsense [Bot], MagsH72
