MK7 Engine rough, smoke and oil in engine bay
Re: MK7 Engine rough, smoke and oil in engine bay
Postby rossco_pb » Mon Nov 03, 2025 12:38 am
Going to try and find an engine - hens teeth in NZ but looks like the UK has a few on offer - any recommendations on where I might source one ?
"there is always one..."
2009 2.4TD 140ps Duratorq, LWB dual rear wheel
2000 2.4TD 120ps Duratorq, LWB dual rear wheel - 3 tonne campervan
rossco_pb
Postby rossco_pb » Wed Nov 05, 2025 5:43 am
Slowly burrowing in and around this engine and wondering if possible to get rocker cover off while engine is still installed? Mine has the centrifugal oil filter on top and seems to foul on that and possibly some other bits of plastic sticking down from the cover. Any tricks?
rossco_pb
Postby knobby1 » Wed Nov 05, 2025 7:36 pm
rossco_pb wrote:Slowly burrowing in and around this engine and wondering if possible to get rocker cover off while engine is still installed? Mine has the centrifugal oil filter on top and seems to foul on that and possibly some other bits of plastic sticking down from the cover. Any tricks?
Rocker cover should come off relatively easily...just remove the top filter before attempting to remove the rocker cover itself.
I had mine off some years ago and don't remember it being too difficullt.
Postby rossco_pb » Mon Nov 10, 2025 4:14 am
Ok finally got engine out and top end off today and yep - have a hole and crack in number four. Not sure why, have had injectors tested and reports on them all indicate perfectly ok so wtf.... Bore and head looks fine - no apparent damage. I was going to get piston welded if just a hole but because of crack will now replace it I guess and then cross fingers lol
rossco_pb
Postby knobby1 » Mon Nov 10, 2025 9:15 am
rossco_pb wrote:Ok finally got engine out and top end off today and yep - have a hole and crack in number four. Not sure why, have had injectors tested and reports on them all indicate perfectly ok so wtf.... Bore and head looks fine - no apparent damage. I was going to get piston welded if just a hole but because of crack will now replace it I guess and then cross fingers lol
Holes like that are "usually" caused by injector issues.
Gearbox, timing cover, rear main seal retainer and mid-sump needs to come out to get at the big ends unfortunately. Easier to pull the engine.
Postby loot » Mon Nov 10, 2025 11:30 am
You can remove the front bonnet,lights,slam panel,bumper and rads easily in an hour. If you can get a hoist to lift the engine out then you could look at getting a bench to work on ideally so you can play about with the engine comfortably.
Most people tend to spend the time just swapping the engine with a low milage 1. I've only read injectors causing blown pistons from over fueling. If you are confident in stripping it down and fitting new pistons etc and inspecting the rest of the engine for things like main seals,clutch,timing chain kit and giving it a bit of an overhaul where needed then happy days. There are lots of bits to these engines though.
Ids map here
loot
Postby metalworker0 » Mon Nov 10, 2025 3:56 pm
that's a crazy picture ... you clearly see overheating /// not just in one part but in 7 points
would be interesting to see an engine designers or injector experts opinion on this .
NOTE: MAKE SURE YOU CHECK OUT THE OIL JET THAT SQUIRTS COOLING OIL UNDER THE PISTON
see here
a group of 6 pistons .. and onwards description underneath .. the damage is described as lack of lubrication or low oil pressure to piston oil jet
https://highwayandheavyparts.com/blog/p ... KoVv1CKGaM
Postby metalworker0 » Mon Nov 10, 2025 4:36 pm
Take note of paul2012 post down the bottom of the page, link below ,
Part number for 2.4 is , 1316019 . ( note: his is a 2.2)
There is an oil gallery filter .. located as in pictures in the thread --- crank has to come out to replace this filter,if you suspect oil problems to the oil jets.
"https://fordtransit.org/forum/viewtopic.php?f=5&t=172985&p=1594722&hilit=gallery+filter#p1594722
Postby metalworker0 » Mon Nov 10, 2025 5:50 pm
Postby rossco_pb » Mon Nov 10, 2025 7:42 pm
Cheers for the info on the oil jets, will try and find them once bottom off and what, a filter under the crank???
rossco_pb
Postby metalworker0 » Mon Nov 10, 2025 8:28 pm
video here 40 secs in .. also see him flushing the gallery with syringe and cleaning fluid
https://www.youtube.com/watch?v=0-zJhRk_DSI
yeah, see now why i say take engine out
there are no short cuts ... if oil gallery blockage was the cause of the piston damage. it has to be cleaned out
you'll see him also attending to the oil jets
maybe this oil filter thing is planned obsolescence, last for the first 120,000 miles on fords 20,000 mile oil changes .. then blocks up and self destructs engine once the warranty has expired or falls apart at 10 years from ageing of plastic .
Postby rossco_pb » Mon Nov 10, 2025 10:19 pm
Ok a nice sunny day and a n ew challenge - the dual mass flywheel bolts do not line up with the holes in the moving bit and given it a couple of smacks bu seems solid - do I have to destroy it to get it off?
rossco_pb
Postby rossco_pb » Mon Nov 10, 2025 11:49 pm
Don't panic :-) ok found that if locked the flywheel using that very special tool (an old bike spanner) and using my home made special crank pulley bolt removal tool I could turn crank anticlockwise (from rear) and compress the innards and one by one get the bolts out - hoo-bloody-ray...
ok now the ladder stiffer thingy - yea gods what a mission lol
rossco_pb
Postby rossco_pb » Wed Nov 12, 2025 3:38 am
I just want to thank everyone on this group for the help you have offered during this rather stressful exercise for this 70 yo bloke way way down under in NZ. Have ordered a new piston, rings etc and full gasket set and while it apart going to replace turbo (it whistles) and the DMF/clutch as guess it the DMF a bit poked and the clutch comes in the kit. Did consider a non DMF but apparently can be an issue with 6 speed manual box. Now just got to wait for all the bits and clean it up and hopefully get it back together ok and then of course hope it works lol
rossco_pb
