Airthies wrote:What are you swapping it into?kuba976 wrote:Hello, I'm also getting ready to swap to a 2.4. I already have a complete engine with wiring harness and EU4 engine controller. My question is, what else do I need?
If it's a 2.4 going into a pre2014 2.2 Mk7 then it's a straight swap if you've a donor with PCM BCM and throttle pedal (+wiring is also different but can be changed)
If it's a 2.4 going into a Mk8 then more of the Mk8 will need retained and parts modified to fit.
Engine mounts should swap over regardless.
Sent from my Pixel 8a using Tapatalk
Hi ive just swapped a 2.4 into a 2.2 mk7 euro 5
ive change the entire wiring loom under bonnet
changed ecu
changed bcm
the van runs but the throttle wont work do you know what the soloution is ive tried the euro 4 pedal and still no luck
thanks
