MK7 2.2 100 T280 fwd starts, revs 1500 2000 & cuts out
Re: MK7 2.2 100 T280 fwd starts, revs 1500 2000 & cuts out
Postby mjsroofing » Sat Feb 07, 2026 8:57 am
Sounds a bit like egr sticking open too, maybe blank that off temporarily to rule it out, cheap and easy.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby dangerous brain » Fri Mar 13, 2026 10:49 am
After a significant wait for a reputable garage that takes vans to be available its been diagnosed as the EGR valve by their software. So I have a question now. How comes Forscan didn't pick that up at all? No codes nothing.
Replacing an EGR is within my skillset so I could tow it home and save myself the labour but there's more than one aftermarket option available and from the online pictures they all look the same and most say they are compatible but are they? Secondly does the ECU or new valve need coding in any way?
dangerous brain
Postby trnx » Fri Mar 13, 2026 4:54 pm
dangerous brain wrote:Well I have changed the fuel filter, the diesel in the bowl had quite a bit of black particulates in it. Refilled the bowl with clean fuel from my diesel heater tank, put it all back together and bled it at the schrader and by cracking the injector pipes off.
After quite a bit of cranking it fires up with full throttle only and revs to just over 500 rpm and cuts out after a few seconds of labouring. Now there's lots of smoke as well.
This is not boding well at all.
Need to know the year of manufacture of the van.
Mk 7 2006 to 2011 not the same as 2011 to 2014.
On the 2011 to 2014 there's no need to undo the injector pipes when bleeding the fuel system.
On any engine if the pipes are incorrectly tightened and sometimes loosened they'll break sometimes.
It is likely that if the EGR is open there would be difficulty in starting - once started it is likely the engine could keep running - the engine could not perform well at higher rpm under load. If there is an exhaust restriction and the EGR is open then the engine is likely to stop.
Mk 7 E5 DPF RWD XLWB SRW
trnx
Postby metalworker0 » Fri Mar 13, 2026 5:07 pm
dangerous brain wrote:After a significant wait for a reputable garage that takes vans to be available its been diagnosed as the EGR valve by their software. So I have a question now. How comes Forscan didn't pick that up at all? No codes nothing.
myself if i had the task of buying a replacement EGR .. it would be a Ford branded one, also known as FoMoCo or Motorcraft, and made by German company Pierburg, so can also be branded Pierburg.. so any of these and you are buying the top makes.
Go to cat car.info.. nearest i can get you without the year!
http://www.catcar.info/ford/?lang=en
.. Get the part number and put it into ebay --- noting the brands above
Postby knobby1 » Fri Mar 13, 2026 9:53 pm
A faulty EGR valve will not cause the engine to cut out.
Lord Knobrot (Smithy)
Postby ELLIOMAN » Wed Apr 22, 2026 3:59 pm
OP - Did you get this sorted? mine is doing the same
Cheers
ELLIOMAN
Postby knobby1 » Wed Apr 22, 2026 7:50 pm
ELLIOMAN wrote:OP - Did you get this sorted? mine is doing the same
Cheers
He hasn't been back since March 13th...we may never know.
Postby mjsroofing » Wed May 13, 2026 7:06 am
I have witnessed a stuck wide open egr cause engine ro cut out.
But I guess we'll never know now.
mjsroofing
Postby knobby1 » Wed May 13, 2026 7:59 pm
mjsroofing wrote:I have witnessed a stuck wide open egr cause engine ro cut out.
EGR valve is normally open at idle anyway and progressivly closes as RPM, throttle position and load increases...if the engine is cutting out, it won't be the EGR valve causing it.
You can remove the EGR valve altogether and the engine will still run...not happily, but it will still run.
