andz327 wrote:sounds about right, remove water hose and manually open valve from inside the pipe and put back on and try it for heat
Appears the valve is operating ok, took it off and the control actuator arm thingy changes the flow of water when I push it in manually. Seems there might be some heat passing through the pipes into the heater matrix when the vacuum is unplugged and the control arm is out but that doesnt translate to heat at the vents (nor when i twist the heat control dial does the control arm move in or out)
COnfusing!!
