Thermostat to egr hose
Re: Thermostat to egr hose
Postby Parky7 » Mon Jun 22, 2026 6:19 am
Thanks for your reply…
The news I was dreading really???
I will try the rubber glove test as I don’t have a pressure tester… I will try a different brand of sniff tester to see if that gives a positive result…
Then I will have to strip it all down and get the head skimmed or a new one if cracked.
Out of interest does anyone know roughly how much for a head skim
It’s a shame as otherwise the van is running sweet, it is a converted camper so only has light use really.
Parky
2010 - MK7 100/350 LWB Hi-Top
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby tranmx2 » Mon Jun 22, 2026 8:00 am
Check vent at the back of the header tank is clear.
2012 2.2 TDCi MK 7 E 5 100 HP - 350 3.5 tonne XLWB RWD H3 L4 Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM Siemens Continental fuel system.
OBD2 ELM 327 FTDI and Vlinker . Forscan 2.3.46
tranmx2
Postby Parky7 » Mon Jun 22, 2026 1:26 pm
Will check this
I will try a new thermostat just in case (as i would replace if the head needs to come off anyway)
Out of interest with the excess pressure in the system, would or should the coolant cap vent pressure out or not …
Parky
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby metalworker0 » Mon Jun 22, 2026 3:24 pm
only if it goes over 20 psi
which is what tranmx2 has on it in his diagram
Postby knobby1 » Mon Jun 22, 2026 8:00 pm
metalworker0 wrote:only if it goes over 20 psi
It's actually 21psi for the 2.4 Euro-4 engines.
Lord Knobrot (Smithy)
Postby Parky7 » Tue Jun 23, 2026 9:15 am
Yes sorry, didn’t notice the psi on the drawing- getting old eye sight not what it was :D
Thanks for the info chaps as always
I will try a new stat and cap and give the system a good flush out at the weekend, then take it for a blast up the motorway then check to see if the hoses and tank are still pressurised when cold , if they are I will get the head off
And have a pressure test done
Will report back when I have some news…
Bit busy at work this time of year, so it will probably be a couple of weeks until I can get the head off…
Parky
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby metalworker0 » Tue Jun 23, 2026 4:16 pm
Bet its going to be different all over the country , but according to google AI its £60 - £100
and you never trust them on cleaning afterwords .. make sure its spotless yourself by doing the cleaning in the galleries etc.
and it may not be as simple as you think
You may need to buy extra thick gaskets afterwards, because the valves are almost flush with the head face, tools needed to measure etc .. piston protrusion etc to calculate gasket thickness original had notches in it to indicate its thickness.
With the info above AND BELOW .. by When the time comes, you'll be clued up and not make mistakes
Dial indicator with stand - cheapest i could find
https://www.ebay.co.uk/itm/227368745960?
The gasket thickness is with notches - ford call it tooth
part numbers
1349874 1 notch thinnest
1349875 2 notch thicker
1349876 3 notch even thicker
That's all ford OEM go up to
See this one .. 4 notches -/ teeth can be clearly seen NOTE LINK FOR ILLUSTRATION PURPOSES ONLY - NOT YOUR GASKET
https://www.ebay.co.uk/itm/166351006494?
Sorry, don't know the actual measurement of thickness .. machine shop should advice.
also could have been skimmed before and beyond the point of another skim.. it would make it more work to return to standard after this --re-cut valve seats etc £££
Postby Parky7 » Thu Jun 25, 2026 5:14 pm
Thanks Mark for all the info much appreciated…
I did get rough quote from a local machine shop, £120 + vat (south east England prices) more if it needs cleaning??
Not sure on the history of the van, so it may or may not had a skim before
Once I get the head off I will update more ,I will order a dial gauge in anticipation?? Always handy to have anyway…
Parky
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
