Timing Chain Replacement
Re: Timing Chain Replacement
Postby metalworker0 » Wed Jul 15, 2026 7:15 pm
same position here as you .. not done before .. i would not be looking for that hole .. i would be buy the correct tool to lock the timing chain side.
far as i can make out, the hole in the flywheel side is for using with a device that fits into it .. this device looks nothing like a pin that fits into a round hole
so
https://www.ebay.co.uk/itm/293730973254?
and is used for locking the flywheel and NOT timing it, it is used to stop the flywheel turning when undoing crankshaft nut etc.
so buy the correct tool kit that fits the timing chain side.. and do it the correct way
The manual is absolutely useless .. does not even tell you how to use the tool .. just shows a pic of it set up , with no clue how.
The manual is probably the worst thing, as far as helpful is concerned, it isn't, how ford techs get on with it- i don't know .. the dealership guys must just pass the information on from tech to apprentice .. cause you'll never in a million years follow the manual .
oh and the 2.2 defender manual shows no flywheel locking tool and tells you to put in first gear and keep foot on brake whilst someone loosens crankshaft nut!
Postby metalworker0 » Wed Jul 15, 2026 7:58 pm
oh .. and according to google AI
the engine is fitted to other vehicles
so if anyone can tell me which of these AI statements is true ,, will go off and find a better properly written manual, if found .. that will be the one we use .
1. Vans and MotorhomesFord: Transit, Transit Custom, S-MAX, GalaxyFiat: Ducato (marketed as the 100 Multijet)Peugeot: Boxer (marketed as 2.2 HDi)Citroën: Relay / Jumper (marketed as 2.2 HDi)2. 4x4s and PickupsLand Rover: Defender (2.2 Puma model years)Ford: Ranger T6Mazda: BT-50 (shares the T6 platform)Ford: Everest (SUV based on the Ranger)3. Passenger CarsJaguar: X-Type 2.2d, XF 2.2dFord: Mondeo (2004–2014)
defender one .. got it .. not that brilliant to be honest .. uses a lot of the transit manual info
Postby Smelly Dog » Tue Jul 21, 2026 2:16 pm
Transit Crank Lock.mp3
Think I've found it.
Smelly Dog
Postby metalworker0 » Tue Jul 21, 2026 2:42 pm
that's "sound only" file
Postby sierra3dr » Wed Jul 22, 2026 8:20 pm
I have skimmed through this post :mrgreen: where is the crank sensor on these? What I am thinking is,if the CS is mounted pointing to the flywheel,perhaps you can chock it once the CS is removed. I perceive that you have removed the starter?
sierra3dr
Postby knobby1 » Thu Jul 23, 2026 12:38 am
sierra3dr wrote:I have skimmed through this post :mrgreen: where is the crank sensor on these? What I am thinking is,if the CS is mounted pointing to the flywheel,perhaps you can chock it once the CS is removed. I perceive that you have removed the starter?
The crank sensor is indeed "pointed" at the flywheel...however, the sensor mounting bracket is quite fragile and cannot be used to lock the flywheel/crankshaft, it's only used to allow correct cam timing setup using the appropriate timing pins. If the bracket is damaged or broken...it's a "gearbox out" job to sort it.
Lord Knobrot (Smithy)
Postby sierra3dr » Thu Jul 23, 2026 4:41 am
knobby1 wrote:The crank sensor is indeed "pointed" at the flywheel...however, the sensor mounting bracket is quite fragile and cannot be used to lock the flywheel/crankshaft, it's only used to allow correct cam timing setup using the appropriate timing pins. If the bracket is damaged or broken...it's a "gearbox out" job to sort it.
oh I see,I surmised that it goes through the block and bolted onto the block
sierra3dr
Postby sierra3dr » Thu Jul 23, 2026 4:45 am
Smelly Dog wrote: I'm struggling to find the correct place to lock the fly wheel. There is one spot where there is a large gap in the teeth but there is play when the locking tool is in through the crank sensor hole.
ah,you did mention the CPS hole
sierra3dr
Postby Smelly Dog » Fri Jul 24, 2026 7:05 pm
Got it all timed up. All put back together. Slight problem there is oil coming out of the "extra" hole at 11 o'clock on the cover. Is something supposed to go in it? I put sealant all the way round it.
Smelly Dog
Postby Smelly Dog » Fri Jul 24, 2026 7:08 pm
metalworker0 wrote:that's "sound only" file
Bugger! It won't take MP4 for some reason!
Smelly Dog
Postby Smelly Dog » Fri Jul 24, 2026 8:02 pm
Thanks for all your help. I finally fond the time to carry on and found the right slot.
https://youtube.com/shorts/ELidlxKZTXg?feature=share
The engine is running ok. Next problem is the oil pissing out of a hole in the timing cover. Photo to follow!
Cheers fellas!
Smelly Dog
Postby metalworker0 » Fri Jul 24, 2026 8:09 pm
yup no picture in the manual .. only vagueness
will try looking for the boxer manual tonight .. see if we get a better explanation
Postby metalworker0 » Fri Jul 24, 2026 8:31 pm
site is slow
haven't worked out how to save it
its telling you on page 10 how to lock flywheel
not had time to have a good look
if i can save it will upload it to google
fiat ducato 2.2 manual
https://pdfcoffee.com/qdownload/fiat-du ... -free.html
every time i try to save, its blacks out with pic of jigsaw piece .. no choice to "save as " only the save icon on the pdf
Postby metalworker0 » Fri Jul 24, 2026 8:43 pm
ok guys have a look at the link above .. i have managed to download it
just take the time to have a look at it .. and confirm its good for info or not
and i will uplaod to my google if good
Postby Smelly Dog » Sat Jul 25, 2026 9:40 am
SO after a bit of research I've discovered that the 8mm freeze dish shaped welch plug has disappeared and there isn't a new one in the timing kit. That's why the oil is leaking out. You can get a zinc replacement or apparently belt and braces is to clean the hole thoroughly with brake cleaner and a rag and fill with JB Weld. Going to try that tomorrow.
Smelly Dog
