BART wrote:Six gear on my 135 is 28 mph/ik rpm. 70mph on the gps is 2450rpm.
Had a 115 5speed and 70mph was 2900 rpm.
coconut wrote:just to complicate it a bit more
System Operation
Power transmission route in 1st gear
The 1st gear wheel is positively connected to the 1st to 4th gear output shaft by the 1st/2nd gear synchroniser assembly.
Power transmission route in 2nd gear
The 2nd gear wheel is positively connected to the 1st to 4th gear output shaft by the 1st/2nd gear synchroniser assembly.
Power transmission route in 3rd gear
The 3rd gear wheel is positively connected to the 1st to 4th gear output shaft by the 3rd/4th gear synchroniser assembly.
Power transmission route in 4th gear
The 4th gear wheel is positively connected to the 1st to 4th gear output shaft by the 3rd/4th gear synchroniser assembly.
Power transmission route in 5th gear
The 5th gear wheel is positively connected to the 5th/6th/reverse gear output shaft by the 5th/6th gear synchroniser assembly.
Power transmission route in 6th gear
The gear wheel of the 4th/6th gear drives not only the gear wheel of the 4th gear but also of the 6th gear.
The 6th gear wheel is positively connected to the 5th/6th/reverse gear output shaft by the 5th/6th gear synchroniser assembly.
Power transmission route in reverse gear
The reverse gear idler is welded to the 1st gear wheel. It is constantly engaged with the reverse gear wheel (shown separated for clarity).
The reverse gear wheel is positively connected to the 5th/6th/reverse gear output shaft by the reverse gear synchroniser assembly.
4th & 6th use the same gear, my head my head
winterheating wrote:does this gearbox have different oil to the standard 5 speeds
Users browsing this forum: Google Adsense [Bot], metalworker0
