It may be present and not active for some reason, as reported by other members above. What is your van/engine/final drive ratio combination? If you were to attempt to reach 50 mph in 3rd gear, surely it would come on if it were functional.dethleffs wrote:My van has the green arrow and the only time it comes on is when I turn on the ignition and all the dash warning lights come on.
At what revs is it coming on? Am I being too gentle with my van?
Vee4 wrote:In my experience with the 6-speed, 115 PS TDCi, the ranges I use, roughly corresponding with the SIL:
1st and 2nd gear as required
3rd gear up to 30 mph
4th gear 30 to 40 mph
5th gear 40 to 50 mph
6th gear 50 mph and above
Reverse gear 70 mph and above
Including the reverse gear range?Mike Spence wrote:That seems very similar to my driving style.
Vee4 wrote:It may be present and not active for some reason, as reported by other members above. What is your van/engine/final drive ratio combination? If you were to attempt to reach 50 mph in 3rd gear, surely it would come on if it were functional.dethleffs wrote:My van has the green arrow and the only time it comes on is when I turn on the ignition and all the dash warning lights come on.
The SIL favours RPM between 1500 and 2000, and on the 115 PS TDCi, maximum torque is around 1800.
Here is the Ford news item from December 2008, so it seems that your van should have it and it should be working. Do any Ford 'insiders' here know why some work and some don't?dethleffs wrote:I think it's bust then! My van is a 350m 2.2 140ps 2009.
That makes sense because that would be the response of one of the old vacuum-operated 'economy gauges' on a petrol engine, e.g. http://www.procarcare.com/icarumba/reso ... sp#Figure7.foggy08 wrote:In our luton mk7 itcomes on when you stop accelerating ....ie if it comes on and you accelerate more it goes out. So if you acc ,change acc, change till you get to 6th you dont see it. If you level out in 1st 2nd 3rd 4th or 5th at any speed it will come on.
Grenadekid wrote:Stick a bit of black insulating tape over it on the dash screen, job done
simsons51e wrote:So i guess the answer to the orig' post ... is ... Yes, I Think It Can Be ![/b]
