TBH, the management system sounds like it's doing what it's supposed to do.
When the PCM sees a temp signal of +125degrees it decides to bury the needle in the red zone and send the signal to the fuel pump for reduced power, if the temp signal doesn't reduce quickly enough it'll cut the engine and turn on the mil light (the glow plug light)
