heaters not blowing hot air, cold air only
Re: heaters not blowing hot air, cold air only
Postby nick-barnes07 » Fri Oct 23, 2009 7:47 pm
100 T280 wrote:
nick-barnes07 wrote:anyone know if it could be a heater control valve , do the transits have heater control valves like other fords?????? one of these i meanhttp://cgi.ebay.co.uk/HEATER-CONTROL-VA ... 3ef8d6f046
Only with A/C.
What Mk, and has it got A/C? With A/C, temperature selection is controlled by stepper motor on blend door, and these can stop working, sticking on last position regardless of temperature selector knob.
mk7 and no air con,
nick-barnes07
Postby nick-barnes07 » Thu Nov 12, 2009 11:25 pm
anyone know what this could be, changed the thermostat and that didnt solve it even though the stat was sticking
nick-barnes07
Postby nick-barnes07 » Thu Nov 12, 2009 11:31 pm
winterheating wrote:
nick-barnes07 wrote:bit of a weird one, i think it may be a bit more indepth than i know of, i am going to get it booked into ford's when i get payed and get them to have a look at it,
whys it weird one, the stat and rad are working correctly, :?:
if both top and bottom were same temp it would show water pump is working but stat fully open, its not that.
if it over heated and blowers work and rad is cold, it would show main stat stuck shut, its not that
if it didnt over heat, flow through rad was ok, dont have circulation of water through blowers, it means............................ stat is working ok and cooling is working by gravity through rad but water pump isnt working fully
so do you suggest bang a new water pump on it???
nick-barnes07
Postby psv-hgv-flt » Fri Nov 13, 2009 11:18 am
it might be this shut of valve, i had this prob on mk5, this is pic of mk6. or take pipes of and put steam-cleaner hot through it and see if its hot then, as done loads with coach heaters.
might be in the dash prob.??
psv-hgv-flt
Postby nick-barnes07 » Fri Nov 13, 2009 9:10 pm
ill check it tommorow if the weather gets better, will it be in the same place on the mk7
nick-barnes07
Postby psv-hgv-flt » Fri Nov 13, 2009 9:21 pm
nick-barnes07 wrote:ill check it tommorow if the weather gets better, will it be in the same place on the mk7
not shure, but have a look, and thats what it looks like. if the smaul vac pipe is off that can happen or tie it open. :wink:
psv-hgv-flt
Postby nick-barnes07 » Sat Nov 14, 2009 8:48 pm
sorted now, was the cable coming of the heater control, need to get a new cable!!!!
nick-barnes07
Postby winterheating » Mon Nov 16, 2009 3:14 pm
if youd listened to your very first reply you would of identified the problem straight away.
winterheating
Postby Adrian99 » Fri Oct 18, 2019 10:33 pm
MK 7 With Air Con My Heater blows cold for up to 1/2 hour first time in the day, the engine temperature is normal and if you turn the blower on and change it from cold to hot you can hear the flap changing the air
After the varied time it goes suddenly hot and is fine for the rest of the day i can change it from hot to cold and it works fine
i did check the pipes to the heater and they were only Luke warm is there anything that could stop the water flow to the heater.
Thanks winter will soon be here brrrrrrrrrr
Adrian99
Postby loot » Sat Oct 19, 2019 9:09 am
Sounds like the matrix is blocked to me
Ids map here
loot
Postby knobby1 » Sat Oct 19, 2019 9:12 am
Adrian99 wrote:MK 7 With Air Con My Heater blows cold for up to 1/2 hour first time in the day, the engine temperature is normal and if you turn the blower on and change it from cold to hot you can hear the flap changing the air
Holy thread resurection Batman...Ummm....this thread is nearly 10 years old :mrgreen:
Postby loot » Sat Oct 19, 2019 9:14 am
Let no one be left behind :lol:
Ids map here
loot
Postby bambi mk 1 » Sat Oct 19, 2019 9:37 am
At least it proves he done a search Knobby ,plus it is stops people posting whats been posted already .Up here we use our head for thinking with ,not walking with :mrgreen: :wink: :P
bambi mk 1
Postby rodduz84 » Fri Dec 10, 2021 10:47 pm
This got to be due a resurrection so here it is
Got similar issue. Engine gets up to temp, console knobs don't work but they do turn directly on the heater box in driver's footwell. Srill onlt blows cold.
What are the two pipes winter mentions to check to see if circulation is actually taking place? The two at rad, one going to it which gets hot when engine up to temp and stat opens and the one leaving rad?
If both hot I have circulation yes?
Sent from my SM-G991B using Tapatalk
rodduz84
Postby knobby1 » Sat Dec 11, 2021 8:53 pm
Do you have A/C..?? If so, your blend door actuator may not be well ...or the vacuum powered heater tap is faulty..
