did you take intake off and do a compression test first then
with the timing out i would defo take rocker cover off and check for loose bolts though.
the tensioners are £52 from ford not worth reusing an old one.
dont worry about the cover they always have a curve in them when you take them off.
once its back on with some decent gasket sealer it will pull it back straight, also if needed you can just tap any bent bits straight when fitted again.
angeleye i still havnt used that sealer you gave me yet, but will be doing my own 2.2 tdci conversion soon, so will need it then.
the sprockets are to be loosend and then chain tensioned with tensioner to take up the slack, the cams themselves and pump itself will be locked anyway, then whe3n slack in chain is taken up tighten all bolts
the tddi injectors are often over looked they can cause all sorts of problems just like any injectors, but they normally will still work even when very worn unlike the tdci injectors as youll know, as the have to work to such very fine tolerances.
plus just like anything they can fail.
theres 2 places the flywheel pin can go, just make sure the torx bolt on end of crankshaft points to 11 oclock or this position
and cams in this position not 12 oclock
