Towing Capacity
Re: Towing Capacity
Postby winterheating » Wed Feb 16, 2011 2:48 pm
A mondeo estate can tow more trhan a 260 or 280 SWB LHR transit its mad.
You can get 350,330,300 FWD aswell.
winterheating
Re: Towing Capacity
Postby geddly » Wed Feb 16, 2011 3:16 pm
I had a front wheel drive that i pulled my boat with and found if you got on a slippy surface like grass or mud i lost traction, much better with my rear wheel drive, the weight is on the drive wheels. just my opinion. 8)
Grand Cherokee Overland V8
Honda CBRXX Super Blackbird
geddly
Re: Towing Capacity
Postby TIMO » Wed Feb 16, 2011 8:51 pm
ill be towing is 2005kg then weight of trailer which im yet to find out
You definately need a RWD 350/135PS OR 140PS mate , and something with GTM OF 6000, BASICALLY THE BIGEST YOU CAN GET HOLD OF oops caps Forget the FWD ,, THERES NO CHANCE AT ALL ITLL PULL 2005 + THE weight of a trailer
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Re: Towing Capacity
Postby apples26 » Wed Jul 08, 2015 6:38 pm
Blimey my Kia Sorento has a 2.8t Mac towing weight! I was considering replacing it with a transit but maybe not then?
http://WWW.NEEDATOW.CO.UK
apples26
Re: Towing Capacity
Postby paul2012 » Thu Jul 09, 2015 2:08 pm
Always check vin plate/label :idea:
I have 2 mk6's here at the moment. Both are T280S 2.0 TDDI 100ps, Engine Code ABFA with SVO Application/Label
2006 model GVW 2800kg, GTW 3500kg
My 2003 model GVW 2640kg, GTW 3500kg
Difference between the 2 models is :-
2006 has gearbox ratio of 4.23 with lower manufacturers emission limit of 0.96 & GVW 2800kg
My 2003 has gearbox ratio 4.54 with higher manufacturers emission limit of 1.32, GVW 2640kg
& a special edition pack (which I don't have a clue to what that is :? )
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Towing Capacity
Postby ake » Thu Jul 09, 2015 8:24 pm
paul2012 wrote:Always check vin plate/label :idea:
Not sure why we are resurrecting a dead thread, but any way, the early 260 and 280 had lower weight figures than the later models, not sure why, Ford messed it up somewhere
Re: Towing Capacity
Postby Altransit » Thu Jul 09, 2015 9:39 pm
ake wrote: Not sure why we are resurrecting a dead thread, but any way, the early 260 and 280 had lower weight figures than the later models, not sure why, Ford messed it up somewhere
Yes, I never checked my 280 when I bought it, but luckily it had the proper 2800GVW as befits a proper 280 :P :lol:
Re: Towing Capacity
Postby cjl » Fri Mar 31, 2017 8:50 pm
Hi folks,
Looking at getting my first transit but need to do a bit of towing so just wanting to clarify something. I want to check whether the following scenario would be ok as I'm getting mixed information from different places. Ignoring things like FWD/RWD, take the following:
GVW = 2600kg
Kerb weight = 1600kg
GTW = 3500kg
MAM (trailor) 1500kg
If I loaded the van with 400kg of stuff (people, equipment etc) so that it was at 2000kg, would towing the 1500kg trailor be ok? Still below the 85% (1700kg), so I'm ok to do this right? Some have said I shouldn't tow more than 900kg with such a setup, but presumably this is only if the van is fully laden?
Thanks for your help.
cjl
Re: Towing Capacity
Postby ake » Sat Apr 01, 2017 1:03 pm
cjl wrote:Hi folks,
GVW = 2600kg
GTW = 3500kg
Yes, that would be legal, just! As you would be at your max GTW of 3500kg
Re: Towing Capacity
Postby davyjcb » Sat Apr 01, 2017 1:36 pm
An once you pass 3500 kg you technically should have tacho
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Re: Towing Capacity
Postby v8dave » Sat Apr 01, 2017 2:26 pm
davyjcb wrote:An once you pass 3500 kg you technically should have tacho
GTW or GVW ?
Also depends on vehicle type and usage.
Leisure activities, camper van?
Government information is vague, but it's been to court enough times that there are precedents.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: Towing Capacity
Postby (ROG) » Sun Apr 02, 2017 6:43 am
cjl wrote:Hi folks,
GVW = 2600kg
GTW = 3500kg
The 85% advice is for caravans only
B+E licence needed as total MAM is 4100 so over the 3500 B licence towing limit
Tacho needed if for commercial use and none of the exemptions apply
What is the max listed towing capacity for this van :?: - I thought it was 1200 max ............ ADD = looking back at other posts it seems it does have a 1200 max towing capacity so if the trailer has a MAM of 1500 and is say 500 empty them the max which can be loaded into it is 700
EX IAM car and commercial observer
(ROG)
Re: Towing Capacity
Postby Altransit » Sun Apr 02, 2017 2:11 pm
(ROG) wrote:What is the max listed towing capacity for this van :?: - I thought it was 1200 max ............
My Mk6 280 has a max trailer weight of 1550kg, and I thought that the 260 was the same :?
Mine is stated in the V5 :)
Re: Towing Capacity
Postby cjl » Tue Apr 04, 2017 8:22 am
Thanks for the responses so far. A little more info in response to questions:
@v8dave - It will be a camper van, however I doubt I'll have done enough in terms of conversion to get it transferred over "officially" to a "motor-caravan".
@(ROG) - that's interesting (albeit frustrating) and thanks for pointing out. However, since the GTW I've put is 3500kg, does that not over-ride the MAM of 4100kg (GVW + MAM of trailer) since I could never tow that much? I've not actually decided on the model of van yet, but looking increasingly like I'll have to go for a 330 (RWD/AWD), so it will have a decent towing capacity. I was looking at a 260/280 before, but the FWD is putting me off as I may be in a situation where I need the traction (trailer will be a horse-box and may not always be on a "road").
If I do go for the 330, then I think it'll be more like a GVW of 3500 and GTW of 5500, which will be fine for the jobs I need it for, but by the sounds of it I'll for sure need the B+E licence...
Cheers
cjl
Re: Towing Capacity
Postby man le-mans » Tue Apr 04, 2017 9:18 pm
I've got a 350T 115bhp fwd and the Total is allowed to tow 2.8 tons, with the van maximum loaded to 2.7tons.
If van is loaded to its maximum of 3.500 tons I can still tow 2.000 tons.
I've never had any problems with my fwd towing my trailer and track cars.
Yes the rwd would be better but I don't have any problems as said
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
