Idiots guide to IDS
Re: Idiots guide to IDS
Postby transit-town » Sat Jan 06, 2018 12:01 am
Hi lads,new to diagnostics and came across these ex AA systems,are they any good as deal with all http://www.adverts.ie/14427136
transit-town
Postby explorer2013 » Wed Feb 07, 2018 2:08 pm
Please Help!
In IDS "Programmable Parameters" menu list there are no "Car Configuration Parameters". In engineering mode (code 60274) in the list there are no Ford Explorer U502. If I put in my VIN - error window "VIN out of range. The range is to ."
How can I pick my Explorer (U502)?
I know that Explorer is not Transit, but I am searching every where for info.
explorer2013
Postby walt1984 » Sat Feb 10, 2018 6:32 pm
if anyone can help it would be much appreciated
cant get my lap top to connect with vcm, think the xpog extension thing had run out so uninstalled everything to try downloading it again.
is there any order to what i down load 1st ?
got traction, engine management and engine malfunction lit on van so im keen to try and get the vcm working
thanks
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby loot » Sat Feb 10, 2018 7:36 pm
walt1984 wrote:if anyone can help it would be much appreciated
thanks
Xprog is only for module programming, the rest of it should work and it should connect.
It is not uncommon for the supplied usb cable to break like a cheap pair of headphones or Samsung charger socket :?
It is just a printer cable though :-)
W7
Extract v86 xprog v86 licence/crack/patch all to desktop.
Run v86 till restart the laptop don't run ids yet.
Run v86 licence/crack/patch in xp3 mode and as administrator till restart laptop.(hq clone bottom option if asked)
Run xprog as administrator.
Start ids.
Non dealer
00000
United kingdom
Sweet.
If you install later ids it is different.
Ids map here
loot
Postby walt1984 » Sat Feb 10, 2018 7:40 pm
thanks
W7
Start ids.
Non dealer
00000
United kingdom
Sweet.
Thank you loot
Don't understand all of that but I got it working when I bought it so might be able to blunder my way through
Forgot to mention it came up with the 3 boxes
Dealer code and something else
Never seen it before that's why I thought I had let something run out.
Sent from my SM-T285 using Tapatalk
walt1984
Postby loot » Sat Feb 10, 2018 7:43 pm
When xprog runs out it only shows a 'not available' message when you go to module programming, it'll still connect to the van and self test and service functions though :-)
Ids map here
loot
Postby walt1984 » Sat Feb 10, 2018 7:52 pm
Got the laptop to connect to the vcm with the printer lead but getting this message I don't remember seeing before ImageImage
walt1984
Postby loot » Sat Feb 10, 2018 8:26 pm
Is your laptop connected to the internet?
Ids map here
loot
Postby walt1984 » Sat Feb 10, 2018 8:28 pm
loot wrote:Is your laptop connected to the internet?
Think it's in range of WiFi
Managed to get it to work
Not sure if I've read the codes right think it could be a map or mass sensor that's putting engine malfunction message on
walt1984
Postby knobby1 » Sat Feb 10, 2018 11:10 pm
Probably the EGR causing that...very common.
Postby Airthies » Sun Feb 11, 2018 7:24 pm
hey guys
I've missplaced my link to the asbuilt download page, :roll:
can you still get the asbuilt files? and if so does someone have the linkything :?
cheers gents
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Feb 11, 2018 7:27 pm
Airthies wrote:hey guys
cheers gents
https://www.motorcraftservice.com/AsBuilt
Don't let bjt know you forgot or he might strip you of your bsce :lol:
Ids map here
loot
Postby Airthies » Sun Feb 11, 2018 8:44 pm
Why thank you kind sir all sorted and saved
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Feb 11, 2018 8:58 pm
Airthies wrote:Why thank you kind sir all sorted and saved
That's quite alright my man, whilst I was there I thought I'd violate you :shock:
Did you feel it?
Ids map here
loot
Postby Airthies » Sun Feb 11, 2018 9:35 pm
Violate away dear chap, just don't tell bjt that I'm open to such debauchery!
As there'll be a raiding party next time he's north of the border
V86+patch
V86.04
X-Prog
C81
Airthies
