Idiots guide to IDS
Re: Idiots guide to IDS
Postby dargie25 » Sat Jun 15, 2019 12:15 am
Just for anyone's information, the vcm2 I bought came with the sp239b board, like this one: http://www.obdexpress.co.uk/wholesale/v ... ccEALw_wcB
The case looks the same but the board is different to the sp177. The sp239b has no physical reset button and I was unable to downgrade it's firmware via vci manager. If your wanting to use v86 of go for one of the sp177 boards.
dargie25
Postby Bowtay » Sat Jun 15, 2019 7:30 am
I purchased the sp239b I also have the vxdiag I opened the vxdiag it's pretty much the same board fitted into the vcm2 case had nowt but trouble with it. it wouldn't do module programming I have the better board now it has 2 boards in great bit of kit
Sent from my CLT-L29 using Tapatalk
Bowtay
Postby loot » Sat Jun 15, 2019 8:42 am
I think I wrote somewhere not to get the 239b :(
Sp177-c1 is he top spec with wifi board but there's many clones and can be any quality :(
Ids map here
loot
Postby Aquiesce » Thu Jun 20, 2019 5:57 pm
looking to buy an IDS clone for use on my 2013 2.2 350 (125)
I've got a new turbo to fit this weekend, an egr turbo feed and return lines and few other bits, but i fear that even when ive done all that I still have some fuelling issue so I think Ill be needing it instead of guessing at the issues!
Can anyone link me to the right bit of kit please as I dont want to go wasting money on the wrong bit of kit.
I have a panasonic tough book running windows 10 that I use for VAG-COM, I presume this will be adequate, Im in manchester if theres anywhere Local
Many Thanks
Paul
Aquiesce
Postby loot » Thu Jun 20, 2019 7:54 pm
Not really sure why you'd need it, euro 5 are limited to only clearing the learned values, not sure ids is worth the money tbh. I've cleared the values on my custom a few times and it has made no difference :?
Ids map here
loot
Postby Aquiesce » Thu Jun 20, 2019 9:19 pm
Ah I see, I did not know this I'm a bit new to diagnostics, so what would you suggest for checking what the issues are with my van as far as fault finding?
Aquiesce
Postby loot » Thu Jun 20, 2019 10:14 pm
Forscan is free software and the modified elm 327 adaptor with hs can switch is cheap enough.
Forscan will read and clear codes and configure etc. 8)
https://rover.ebay.com/rover/0/0/0?mpre ... 3667585365
Ids map here
loot
Postby Aquiesce » Thu Jun 20, 2019 10:55 pm
Ok great thanks for the info matey
I'll look into it tomorrow
Aquiesce
Postby loot » Mon Jun 24, 2019 8:25 am
Is anyone able to link etis with their pass thru and go online to network test their van? There is a pilot learn that isn't available on my ids but it's available in service functions in etis.
Or does anyone have a new version of ids that shows injector pilot learn in native service functions? Do I need to upgrade?
Ids map here
loot
Postby Airthies » Mon Jun 24, 2019 8:42 am
loot wrote:Is anyone able to link etis with their pass thru and go online to network test their van? There is a pilot learn that isn't available on my ids but it's available in service functions in etis.
Karl not be able to help? Just up the road from you too
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon Jun 24, 2019 10:04 am
I've pmd him on fb but he uses the ids3 which I don't have.
I'm looking at newer vcm as i only have v96.
I can go to the dealer and ask them to look for pcm update and pilot learn but my local dealer doesn't convince me that he's doing the work, anyway for a simple pilot learn function I really need to be able to do it. I think maybe I'm OK with older transits but limited in the newer ones, can't do keys and red is noisy so I need to update myself i think.
If anyone has ids 110 or newer and a transit custom, could they maybe do a screen grab of pcm service functions please. :o
Cheers.
Ids map here
loot
Postby loot » Mon Jun 24, 2019 7:55 pm
Hmm
Ids map here
loot
Postby dargie25 » Mon Jul 01, 2019 2:05 pm
Hi again, managed to get a working clone with 112.01, but it's having some trouble.
Using manual entry and inputting the pcm number I can connect to the van, but IDS can't talk to the PCM. The van drives fine so I don't believe there's a probleym, I get this message when I run the self diagnosis test:
Any ideas
Also tested connecting to my fiesta and it auto recognised the car instantly.
dargie25
Postby paul2012 » Fri Sep 20, 2019 8:08 pm
HEADS UP. Received email from Ford this morning, regarding Fords new software will be available soon to download - Global Ford Diagnostic and Repair System
(GFDRS)
& yes you'll have to pay to use it....
You will be able to purchase a 48hr, 1 month or 12 month (Annual License). Global FDRS license will incorporate a Ford IDS License.
Access to FordEtis online i.e. mechanical repairs, Wiring diagrams etc. and Global FDRS Applications for unlimited Vehicle Identification Number’s (VIN’s) entered for the Global FDRS License purchased.
***NOTE***
Existing Users that have purchased an Annual Ford IDS License, (via the FordEtis Online Application) from Ford of Europe will be able to use Global FDRS with their existing Ford IDS License until it expires. Once it expires, You will be able to purchase a 48hr, 1 month or 12 month(Annual License) Global FDRS License.
Existing Users that have purchased a Ford IDS License via another supplier/company other than Ford of Europe. Will need to purchase a 48hr, 1 month or 12 month (Annual License) Global FDRS License to be able to use the Global FDRS Application.
If you do not have a licence. You will be prompted to purchase a license through ETIS (Motorcraft licenses will NOT be accepted).
It appears thats there will be a "Changes & Upgrades page" for vehicle modules etc. Which would be VERY HANDY :mrgreen:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Global Ford Diagnostic and Repair System (GFDRS) will eventually replace Ford IDS :idea:
paul2012
