What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby shovelheadrob » Sun May 20, 2012 8:50 pm
I wanted a cat 1 alarm when I ordered mine, but got told I couldn't have it because I've got opening rear side windows. I was also informed that you can't have rear heating with the Limited option, there are some strange quirks in the build process which defy logic. Another being that having a single passenger seat means you have to have a passenger air bag at extra cost, so why not factor it into the price? Then there is no facility to disable it, not a problem for me but it could be if anyone wanted to fit a child seat!
Panther Black 2012 155ps 350 LWB Limited with extra toys
Leather, reversing camera, dual side doors, LED DRLs
shovelheadrob
Postby Mike » Sun May 20, 2012 8:54 pm
I've got the Cobra cat1 alarm Rob, no reason that it couldn't be fitted to your van from what I can see.
Mike
Wind up merchant!
Postby bigjohnthomas » Sun May 20, 2012 9:08 pm
Is the factory fitted one a bit sh*t then?
bigjohnthomas
Postby Mike » Sun May 20, 2012 9:14 pm
bigjohnthomas wrote:Is the factory fitted one a bit sh*t then?
I understand that it turns off if you unlock the van with a 'key'.
Mike
Wind up merchant!
Postby bigjohnthomas » Sun May 20, 2012 10:45 pm
The other month the fob wouldn't let me in so I had to use the real key in the door and a siren went off till I started him
I will carry out further tests :?
bigjohnthomas
Postby Mike » Sun May 20, 2012 10:47 pm
bigjohnthomas wrote:The other month the fob wouldn't let me in so I had to use the real key in the door and a siren went off till I started him
Andyg suggested that it worked from the key
viewtopic.php?f=5&t=102288&hilit=+Cobra
Mike
Wind up merchant!
Postby Altransit » Mon May 21, 2012 12:10 am
Mike S wrote: Andyg suggested that it worked from the key
He did say that, but we tried it in his van, and found that you activated an entry delay bleeper when entering with a key, but I can't quite remember how we cancelled the delay before the alarm went off a few seconds later :oops: :roll: :lol:
Postby ake » Mon May 21, 2012 6:30 am
All the factory alarms I have had on vehicles, on my Range Rover, Discovery, Mondeo, and the current Focus will go of if you open the door using the key, and are cancelled by turning on the ignition
Postby bigjohnthomas » Mon May 21, 2012 8:18 am
Just tried it ...unlock the door with the key he bleeped for a bit then alarm went off turn key in ignition and it shut him up
Would it of shut him up if I used "a key" ? :?
bigjohnthomas
Postby bigjohnthomas » Mon May 21, 2012 8:39 am
Mike S wrote:I've got the Cobra cat1 alarm Rob, no reason that it couldn't be fitted to your van from what I can see.
250 quid and you have to put up with that poor persons interior light :shock:
bigjohnthomas
Postby Altransit » Mon May 21, 2012 8:43 am
bigjohnthomas wrote:Just tried it ...unlock the door with the key he bleeped for a bit then alarm went off turn key in ignition and it shut him up
Yes, that's what happened when we tried it, if you unlocked and opened the drivers door, you had a few seconds of bleeping before the proper alarm went off, just like the access delay on a house/shop alarm. I now seem to remember, (reading what happened on Harry the Lime) that you had to insert and turn the correct chipped key in the ignition to cancel the alarm.
If you opened any other door apart from the drivers, the alarm sounded straight away 8)
Postby Herts » Mon May 21, 2012 8:54 am
Is this the same interior light?
http://www.ebay.co.uk/itm/320910420634? ... 500wt_1287
and would it fit in a MK7 Transit
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby Punto443 » Mon May 21, 2012 5:43 pm
Fixed the selector, washed it and made a attempt to sand down my wheels to paint.
Gave up on the wheels after 10 minutes cos I was bored an ordered mk7 trims on eBay.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Punto443 » Mon May 21, 2012 5:50 pm
Then spent 20 minutes trying to find a ninja's mask off the wee mans Lego man which I eventually found in his car seat that I had taken out the van.
Its Damn tricky to spot a ninja in a transit! :lol: :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby blue estate » Mon May 21, 2012 6:45 pm
Punto443 wrote:Then spent 20 minutes trying to find a ninja's mask off the wee mans Lego man which I eventually found in his car seat that I had taken out the van.
Especially in the load area with standard lights :lol: :lol: :lol:
blue estate
