Idiots guide to IDS
Re: Idiots guide to IDS
Postby Airthies » Sun Sep 22, 2019 9:05 am
And did they supply current pricing for the 48hr 1mnth & annual subscriptions?
Sent from my SM-J320F using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby davyjcb » Sun Sep 22, 2019 9:20 am
The licence is priced in Euro's
48 hrs € 121
1 month €433
1 year €3,300
Extortionate isn't it
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby Airthies » Sun Sep 22, 2019 9:22 am
davyjcb wrote:The licence is priced in Euro's
48 hrs € 121
1 month €433
1 year €3,300
Would of been better value 3 years ago over here
V86+patch
V86.04
X-Prog
C81
Airthies
Postby davyjcb » Sun Sep 22, 2019 9:33 am
If you could get a few vehicle's to do at 1 time it would be not so bad but for anyone who wants to do repairs on their one and only motor it prices them out also it won't work with clones and it holds and records the serial no of the interface, the chassis no of the vehicle being worked on and the diagnostic / programming / initialising of functions carried out on each routine run on fdrs
davyjcb
Postby loot » Sun Sep 22, 2019 12:09 pm
You can't initialize euro 5 or pats now anyway, when all the mk7 vans are gone, so is ids.
Forscan will be the way forward and this key cloning things that plug into the obd port.
Ids map here
loot
Postby davyjcb » Sun Sep 22, 2019 12:30 pm
If you have registered for the Euro security on Ford Etis ,have a fully licensed vcm/vcmm you will be able to code keys and initialise modules,that is why they are recording each visit and what functions are used. It's their excuse big brother you visit it, you leave a footprint
If you go looking for an incode now for Euro 5 and type it in to a proper dealer terminal it will deny the entry - plug me into the mainframe and Ford's server will do it automatically ,no handshake with Fords mainframe no access
They are basically trying to shut all the back doors and take the small man out of the picture a big pot an they want it all
davyjcb
Postby paul2012 » Sun Sep 22, 2019 2:39 pm
davyjcb wrote:If you have registered for the Euro security on Ford Etis ,have a fully licensed vcm/vcmm you will be able to code keys and initialise modules,that is why they are recording each visit and what functions are used. It's their excuse big brother you visit it, you leave a footprint
As for current release IDS (V115.01). It does include FDRS incorporated into it. For vehicle coverage from 2018. As IDS itself only supports vehicles up to MY2018 :!:
The Current FordEtis FDRS online application will no longer be available once Global FDRS software is available (switch on date September 29th)
It's not only Ford. Vauxhall have gone the same way they use GlobalTIS / GDS2
Just to retrofit fit a satnav, you have to request VCI codes direct from Germany before it will work. Fortunately I do have a genune GM MDI to do that :wink: .
Clone MDI's are automatically blocked & user accounts used for access closed.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby davyjcb » Sun Sep 22, 2019 2:54 pm
They are also attempting to close down all non dealer access to their systems, under the competition legislation before they couldn't really hold info off the independents. But now there is an application in to stop access on safety grounds and word is they'll get it. With the arrival of lane avoidance and safety braking systems they are pushing the fact that "they" have specialist training not available to the ordinary 5/8 guy or gal and that is the excuse they need to bring it all dealerbound
davyjcb
Postby Airthies » Mon Oct 07, 2019 10:32 pm
Well back to the old v86.04 and my trusty VCM11
Has anyone seen this, first time I've done any module stuff for s while but never remember getting this where it doesn't display the values in the RH column!?
The drop downs are configurable with options but didn't want to change any and then reload incase the rest is blank and it's going to brick the BCM Image
This is on the 09 3.2
I have just added an extra key successfully as I've misplaced the one that locks, as the spare one has duff buttons and doesn't
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Oct 08, 2019 7:38 am
You need to read the van first to populate the paramaters.
So do the top option then the third option to modify.
Ids map here
loot
Postby Airthies » Tue Oct 08, 2019 8:29 am
loot wrote:You need to read the van first to populate the paramaters.
That was after reading the van.
Anyway, disconnect, reconnect reread and all good. Everything there as it should. Did find this that I thought was interesting... Anyone know more about this Hiden gemImageImage
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Oct 08, 2019 9:07 am
I think they are standard, I've always had them. Ironic though isn't it :lol:
If I get round to it I'll confirm.
Ids map here
loot
Postby Airthies » Tue Oct 08, 2019 9:57 am
One thing I was trying to do but couldn't was increase the tyre diameter, but even going through all the engineering codes I've found there's nothing, but wondering if a change in diff ratio would be too big a jump to correct the differences between diameters and Speedo. Need to get my math's head on
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Oct 08, 2019 10:25 am
There is a user option but it doesn't seem to do anything lol. Have you worked out the % difference?
What about putting your speedo needle up a bit :shock: it'll never read zero though :lol:
Not sure I'd change the diff tbh anyway isn't the vss on the abs so wouldn't change anything?
Ids map here
loot
Postby Airthies » Tue Oct 08, 2019 10:34 am
loot wrote:There is a user option but it doesn't seem to do anything lol. Have you worked out the % difference?
I think the diff ratio is more for shift indicator and cruise settings, but wondered if it'd make any odds, was going to change it as it's getting a different ratio to match the front, as it's currently 3.58 and I need a 3.73
V86+patch
V86.04
X-Prog
C81
Airthies
