Idiots guide to IDS
Re: Idiots guide to IDS
Postby loot » Fri Dec 13, 2019 12:39 pm
It's the best quality 1 that we gamble on.
It really is a minefield mate :(
I've had mine for years and the wifi broke and I keep going through usb cables lol, but the old girl kicks over. Be obsolete soon though unless they invent something worthwhile doing on euro 5/6 etc.
Hence me suggesting that you Swerve it. Your van will get the latest update post 2011 but I really don't think they're bothered making more on an out dated van.
Incidentally what year is yours?
Ids map here
loot
Postby Kev1000s » Fri Dec 13, 2019 12:49 pm
Loot my van is a smiley mk5 lwb , low roof , fitted with jaguar 3.0 v6..! I an going to buy a second van in new year , i have a few mates with mk7,s that are having issurs so was going to buy a vcm 2 .. I can find a version Sp177 with no wifi ,
Regards Kev
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Postby loot » Fri Dec 13, 2019 7:01 pm
Ah ok 8)
Unfortunately I can't suggest anywhere as there really are many different companies cloning them.
I've always said, fire a company a message and I'd they respond then that's a bonus, also be careful with postage and use PayPal or similar in case of a claim. Make a note of order numbers and other info.
You do usually pay more from ebay sellers but they are more accountable. They are few though.
Chinese sometimes takes weeks to get delivered
Ids map here
loot
Postby JB757 » Sun Feb 16, 2020 12:11 pm
http://www.obdiitool.co.uk/wholesale/vc ... -tool.html
Anyone had any dealings with this company / product.
Seems to tick all my boxes for my 2008 transit.
Bit confused by the CFR cable for live data. It sounds like this is needed in order to do fuel pump and injector learns..
Thanks.
JB757
Postby Bowtay » Sun Apr 19, 2020 8:10 am
Hi got a Mk6 transit guy fetched it to me as it had lost security code from pcm to fip iv coded it up its was fine he's rang me saying it's lost its code again what causes this please
Sent from my CLT-L29 using Tapatalk
Bowtay
Postby Airthies » Sun Apr 19, 2020 8:50 am
Bowtay wrote:Hi got a Mk6 transit guy fetched it to me as it had lost security code from pcm to fip iv coded it up its was fine he's rang me saying it's lost its code again what causes this please
Better starting a new thread if it's a van question rather than a question or issue your having with your diagnostics.
Have a search through the forum also as your issue may of been experienced before.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby v8dave » Sun Apr 19, 2020 11:25 am
JB757 wrote:http://www.obdiitool.co.uk/wholesale/vcm-ii-clone-ford-diagnostic-tool.html
Thanks.
The cfr cable is used when trying to diagnose driving faults.
It removes the need to drive around with a laptop connected to the obd port.
You preprogram what data to record and over what timescale, then when the fault occcurs while driving you push a button on the cfr and the data is captured.
Alternately you drive around with an assistant to do the computer bit.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby ediesbra » Sun Jun 21, 2020 12:57 am
Hi folks, have got ids v115.05 working. Don’t suppose you know where in ids you can view the cruise control button resistance do you?? Thanks
2009 Mk7 2.4TDCI Jumbo in Panther Black with air con, cruise control, auto headlamps, auto wipers and hill start assist.
Former -
1998 MK5 150LWB
2005 MK6 Welfare unit 115 350 LWB Hi Top
ediesbra
Postby loot » Sun Jun 21, 2020 9:32 pm
If you go to datalogger and try and find the right place. You might see a sub section for ipc or other items that look like it. Ids has so many sub locations we're still learning and forgetting :lol:
Failing that you can get a multimeter and ping the 2 orange wires at the squib using ohms.
You won't know what values to expect in any case but I guess as long as you don't see an open circuit.
What's the plan?
Ids map here
loot
Postby ediesbra » Mon Jun 22, 2020 4:04 am
Cheers Loot!
Long story short I’ve picked up a euro 5 2.2 mk7. Orange wires are present, have fitted c max wheel. I had a b series bcm, bought a c series (programmed) from Martyn. But still no cruise. Martyn has been great talking me through bits and bobs. I upgraded my ids to v115.05 the other day (massive headache). So just trying to eliminate things. Clutch switch is working correctly (it’s reporting clutch up, partially depressed and fully depressed). So just trying to figure out these buttons. It’s turning into a headache lol!
Former -
1998 MK5 150LWB
ediesbra
Postby loot » Mon Jun 22, 2020 8:21 pm
Martyn will have more experience with euro 5mk7 and adding cruise.
Usually you turn it on and that's it. But cruise won't work if there are any brake/abs system problems or warning lights for certain engine faults.
If you turn the ignition on and you see the green cruise lamp come on and off then as far as I'm concerned it is activated.
That said it may as you know be deciding that it isn't meeting the safety requirements to work.
Can you remind me what fault codes you are getting?
Also a faulty cruise button will bring a fault code up.
Ids map here
loot
Postby Airthies » Mon Jun 22, 2020 9:03 pm
ediesbra wrote:Cheers Loot!
Check your rear light clusters for faults you may be getting a back feed via brake lights which will stop it from activating.
Is your handbrake going off properly?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ediesbra » Mon Jun 22, 2020 10:52 pm
Thanks folks. Cruise button lights up , 1 dtc code for glow plug cylinder 3. I’m gonna take it for another run as I stripped the buttons down tonight to check at there all
Giving readings. Rear lights are brand new mk8 tipper lights. I’ve plugged ids in again and it’s still saying “cruise control” in the correct box. Even the IC has the correct backup. I’m completely at a loss lol! Martyn has been great and talked me through things the other day. I may have to be cheeky and pop in and see him. No warnings regarding cruise at all . It’s a mystery!!
Update***
The live data for the clutch switch shows clutch closed/partially depressed/ fully depressed but a like reading of 3.5%?? Also the stop start isn’t working (both battery genuine ford and tested good) and the shift light isn’t operative either??? Even though it is activated. The van goes like stink so I think it’s been remapped. Could this be an issue???
Former -
1998 MK5 150LWB
ediesbra
Postby ediesbra » Tue Jun 23, 2020 1:26 am
Further update. Swapped the main clutch switch for a known working one off my mk7 jumbo, no better. Pulled the second switch and checked it. Continuity when it’s pressed. Checked the tang and bent it up slightly. Nothing :( getting confused now :(
Former -
1998 MK5 150LWB
ediesbra
Postby Airthies » Tue Jun 23, 2020 7:40 am
Just disconnect the rear lights or recheck them, especially the earth points, I know you say they are new but that doesn't mean there may not be a fault in that system or with the wiring.
I know erroneous signals coming back can cause other systems to do funny things and bring other lights on in the dash but the BCM will be pick up millivolts and that could be enough to stop cruise but not show other tell tails.
Ps. Is it worth moving this fault discussion to it's own thread as it's more about the cruise fault than IDS issues? It's good information and be a shame for it to get lost in this thread.
V86+patch
V86.04
X-Prog
C81
Airthies
