What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby anpservices » Tue May 29, 2012 9:38 pm
Got a shiny new MOT on the '04 plate after its failure yesterday - on four trivial items - brake pedal rubber incomplete, suspected fuel tank leak, both headlights misaligned and excessive smoke...
£4.30 to Ford for a pedal rubber, £1 for a tin of brake cleaner to clean up outside the fuel tank after it got overfilled last week, a tin of Forte and a damn good thrashing bought the smoke from 5.4 to 1.02 and the MOT station aligned the headlights for nowt!
Further comments from the tester where "clutch is crap" - yes I know - and "stinks of grass" - ah yes that'll be the four full builders bags of grass cuttings in the back then.....
So, it now readied for another year of hauling around lawnmowers,hedgetrimmers, strimmers, grass cuttings and garden waste and quite often a ten foot plant trailer......
Till the next thing goes wrong! :P
anpservices
Postby Terry » Tue May 29, 2012 10:27 pm
New set of front pads, got a very slight graunch 10 days ago, inner on drivers side was down to 2 fag papers, other 3 were all pretty similar.
3rd n/side drop link in as many months. The outer is plastic/bakelite seems crazy a plastic suspension component !!!!!!! especially a compressive part, the one (pieces) than came off looked like a pair of jagged collars for the inner bolt ! I'm not a tear-arse, neither has she been overloaded.
Pallet Puller
Terry
Postby bigjohnthomas » Wed May 30, 2012 7:27 am
extreme door modification :)
extra pocket :?:
bigjohnthomas
Postby Terry » Wed May 30, 2012 8:22 am
COPYCAT or should that be COPYDOG :D
Lets see you do this one now :lol: ..................
Have fun
Terry
Pallet Puller
Terry
Postby bigjohnthomas » Wed May 30, 2012 8:59 am
Wow very nice terry you like your pockets 8) 8)
A bit too extremely for me though :lol:
Have you told your insurance :?: :lol:
Is it a lhd door panel?
bigjohnthomas
Postby Altransit » Wed May 30, 2012 9:01 am
OK you two .......................... WHERE did you get the extra pockets :roll: :mrgreen:
:lol: :lol: :lol: 8)
Postby bigjohnthomas » Wed May 30, 2012 10:05 am
Altransit wrote:OK you two .......................... WHERE did you get the extra pockets :roll: :mrgreen:
That information is on a need to know basis :lol: :lol:
Do you have to have a single passenger seat aswell for the near side pocket to get the door to shut :?:
bigjohnthomas
Postby Terry » Wed May 30, 2012 12:11 pm
hi
I have only ever had a single passenger seat so don't know if its necessary. I ordered a LHD drivers door trim and a LHD passengers door lower pocket, from my local friendly (now gone) Ford dealer, but that was long ago in a Galaxy far far away..
(I looked at a Transit in Holland and saw they came same as ours, upper trim on drivers door, lower pocket on pax door, hence my order) The correct side pockets need a little mod for the front fixing, so it uses the same screw as the upper panel, or you can just do same as BJT.
Have fun
Terry
Pallet Puller
Terry
Postby g-man » Wed May 30, 2012 3:27 pm
now them seats DO look comfy :mrgreen:
g-man
Postby winterheating » Wed May 30, 2012 6:44 pm
Terry wrote:New set of front pads, got a very slight graunch 10 days ago, inner on drivers side was down to 2 fag papers, other 3 were all pretty similar.
The drop links? They are supposed to be tightened lightly.
winterheating
Postby Terry » Wed May 30, 2012 7:34 pm
We guessed as much, as the 'apprentice' confessed he installed the last one with the air tool.
Snapped the moment the van was moved I shouldn't wonder !
I still say it's crazy a plastic suspension component.
Have fun
Terry
Pallet Puller
Terry
Postby Beegly » Thu May 31, 2012 8:57 pm
Fitted a mk 3 mondeo drivers seat..... lush :D
Mondeo 130 TDCI - personal use
30t mobile crane - for work
2004 T280 125 TDCI, 183,000 miles. sold
'96 Citroën ax, 58ps. saved me over £1500 in diesel. SOLD, replaced with
2001 Citroen saxo 1.5 d
Beegly
Postby geddly » Fri Jun 01, 2012 10:42 am
Fitted new timing chain and tensioner, oil and filter proper Ford Gear this time not Transit parts shite. No more death rattle. 8)
Grand Cherokee Overland V8
Honda CBRXX Super Blackbird
geddly
Postby Rumble bee » Fri Jun 01, 2012 8:24 pm
Fitted an extra door pocket (cheers BJT)
Also fitted a radio telescope to the roof :wink:
Chris
Rumble bee
Postby shovelheadrob » Fri Jun 01, 2012 9:32 pm
Fitted some headlamp protectors to stick some beam deflectors on as I'm off to Denmark for 3 weeks,
fitted some speakers in the back so as the rear passenger has some toons,
then loaded up with all the kit to do the work out there,
gave the caravan a quick wash, all ready to head for Harwich then overnight to Esjberg.
I stuck it on a weighbridge last week & with a full tank of fuel I was less than 100kg under max GVW, & 500kg under GTW with the caravan hooked up aswell so at least I know I'm all legal! I've chucked all the uneccessary stuff out of the caravan, like the awning & sunloungers etc to save a bit of towing weight & leave a bit of room for a few cases of beer as that is damn expensive over there.
Panther Black 2012 155ps 350 LWB Limited with extra toys
Leather, reversing camera, dual side doors, LED DRLs
shovelheadrob
