loot wrote:If you got it free then it won't matter i guess, have a try, maybe Google and see what that says, maybe the vcm can be hacked? I think i read that it can be unbricked?
The annual licence is something silly like 600 pounds, probably not worth it for the diy user.
loot wrote:Try having the engine running and then go to the process of pcm update and it'll do a voltage check then tell you to turn the key off anyway before it proceeds.
Got 2 chances i guess.
Should show 14.4v at that point.
loot wrote::shock:
Definitely out of the financial scope of the diy user.
@ knobby, It could be that the vcm Is faulty, i forgot you may have already tried, did you try Wi-Fi?
