ned wrote:loot wrote:[qute="ned"]
loot"quote="Altransit wrote:You need Mk6/7 wheel nuts for alloys, vans with factory alloys had them as standard.
You can't use the flat nuts with alloys
You can, the aftermarket alloys for mk7 are flat washer type that use standard mk7 nuts. The custom wheels have tapered ones but the taper is not very wide. I'm thinking of getting a set of custom/mk8 studs and fit them. 14 x 1.5 and then the custom alloy nuts will fit. It's an unnecessary complication created by Ford I think.
Or you could just buy the correct pitch taper alloy wheel nuts, I’m sure somewhere on here there’s a link for them on the bay of e
Those are nasty though they flake and rust quickly and I don't feel 100% safe that the threads won't fall off
[/quote]
Aye, but if only you know someone, an engineer type, with a big shed and a lathe that could fabricate some, that would be perfect or change all the hubs to mk8/custom hubs, anyway that’s all boring, the big question is what diesel V8 are you gonna drop in there with 2 turbos and 500nm torque[/quote]
I will just buy 20 transit custom studs and the stainless covered nuts that are standard,i actually like them. The studs just Knock out.
I've seen some build info.
4.27 diff, I wanted 3.73.
Manual air conditioning though
The engine I can get remapped and as its swb with 3.73 diff will be strong enough,it'll wheel spin like foof i reckon.
Need to source low roof or pop top, and side door number 2 panels.need a tourneo to chop up
