What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Tue Jun 04, 2024 6:20 pm
Altransit wrote:
loot wrote:
Altransit wrote:I replaced my fuel filter today (I haven't done it for a while) in the hope that it was causing my previously smoke free exhaust, to ............... smoke :roll:
Checking the other filters showed them to be virtually mint, but I will change the oil in the next day or so, weather permitting.
Sadly, whilst poking around in the engine bay, it would seem that the injector seals are leaking again, and all of the injector recesses are awash with dieselly spooge. I'm hoping that the injectors won't put up a fight like last time I had to remove them :roll: :evil: :P
I've just done all that on my van, steals weren't leaking but rocker gasket is suspect. Have you got a seat face cutter tool Al? I did 10 gentle rotations each then compressed air blown into them clears all the gunk.
Also a spot of grease on the copper washer if it looks like it wants to come off the injector it may fall off inserting the injector :|
I didn't check the rocker gasket, but No4 injector was bubbling up through the spooge. The leak isn't bad because it's not making a tappy noise like last time, but the engine is getting oily on the front end, and dripping a bit on the driveway, which it has never done before :(
Undo the breather that goes into the rocker and blow down it just to confirm that the filter isn't clogged as it can raid pressure in there also. Did you take the oil cap off while running to see if it is chuffing ?
Ids map here
loot
Postby loot » Tue Jun 04, 2024 6:21 pm
Can anyone recommend a good place for genuine fomoco timing chain kit new?
I'm after the full kit and timing cover.
:D
Ids map here
loot
Postby Altransit » Tue Jun 04, 2024 11:24 pm
loot wrote:Undo the breather that goes into the rocker cover and blow down it just to confirm that the filter isn't clogged as it can raise pressure in there also. Did you take the oil cap off while running to see if it is chuffing ?
Cheers buddy, I'll try those things 8)
Postby loot » Mon Jun 10, 2024 11:30 pm
Thought I'd replace my clutch and brake pedal rubbers. Quick look on ebay, about 2.50 each, or genuine, 45+ each :shock:
What f** planet are they on? Please tell me :roll:
Ids map here
loot
Postby loot » Tue Jun 11, 2024 2:24 pm
Bought this, after ripping the aftermarket laserline alarm out of the van.
And just saw 2 magpies fighting over a rat the same size on my fence then 1 flew off with it. :shock:
Ids map here
loot
Postby loot » Thu Jun 13, 2024 5:07 pm
So I bought corteco crank seal on the 5th and it got dispatched on the 10th and on the 11th i asked if they'd sent it,they called me and said it got lost in the post yesterday they sent dhl to me and it arrived today but it is elring, i don't mind elring the quality looks good and I've used before.
What would you guys put on feedback? Chalk it down to a bad day for them?
Call them a bunch of shite?
Ids map here
loot
Postby Altransit » Thu Jun 13, 2024 5:36 pm
loot wrote:B just saw 2 magpies fighting over a rat the same size on my fence then 1 flew off with it. :shock:
Flew off with your fence? :shock:
Must have been a very big Magpie :P
Postby ned » Thu Jun 13, 2024 6:09 pm
:lol: :lol: :lol: Or a very small fence
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Thu Jun 13, 2024 6:13 pm
loot wrote:So I bought corteco crank seal on the 5th and it got dispatched on the 10th and on the 11th i asked if they'd sent it,they called me and said it got lost in the post yesterday they sent dhl to me and it arrived today but it is elring, i don't mind elring the quality looks good and I've used before.
If it was myself I just wouldn’t leave feedback, my theory is what’s in it for me, you take the time to do the feedback, they get more sales and you get fook all, I was asked to leave a goooooogle review for a cafe once, I asked if I do will I get 10% off the answer was no so why bother
ned
Postby Altransit » Thu Jun 13, 2024 9:37 pm
ned wrote: :lol: :lol: :lol: Or a very small fence
Curses, I never thought of that :roll: :P
Postby loot » Thu Jun 13, 2024 10:56 pm
I was thinking of not bothering as the saying goes,if you can't eat something nice etc :lol:
Ids map here
loot
Postby loot » Thu Jun 13, 2024 10:57 pm
Ahem :lol:
Ids map here
loot
Postby ned » Fri Jun 28, 2024 10:23 am
2 weeks till mot time so thought I’d better stop procrastinating and get these parts done, look shiny
ned
Postby Jeanclaudedamnvan » Sun Jun 30, 2024 3:49 pm
Today the replacement fuel rail return hose set up got delivered - this was ordered on Amazon prime yesterday, thank goodness for next day delivery. I was replacing the fuel injector seals, there are 3 per injector, one thick copper washer which seals the injector into the cylinder head, one large rubber seal which stops crud going into the cam cover and a very small o-ring which fits into the fuel return pipe (this is clipped into the top of the injector). Upon re-installation the fuel return pipe broke off as I tried to re-insert it into the injector. Over time plastics become brittle with the hot and cold cycles of the engine, the van is 10 years old and has only done 90,000 miles.
Replacing all of these seals is easy enough with care and a certain amount of insight. The clamp bolt I'm assuming is supposed to be replaced when after you remove it but the seal kit I got from eBay had the wrong length bolts so I had to re-use the old ones. Once the clamp bolt is removed the injectors can be wiggled free with a little force. Be aware of the copper washers on the end of the injector, if they are missing then they are stuck to the head and will need careful removal. To avoid the new copper washers falling off when you re-insert the injector, i used a small dab of Loctite to hold it in place. Before you re-insert the injectors, vacuum the area around the top rubber seal to avoid debris getting inside the engine, then replace the rubber seal. These will be hardened from years of service and will take a bit of persuading to remove - a blunt screwdriver works well.
Anyway, when I tried to re-install the fuel return fitting (on the pippe), it snapped and this was probably due to the new o-ring being much thicker that the original - again I was let down by the set from eBay, you need new green o-rings but the ones that came with the kit I got were the wrong szie (see photo) I ended up buying a new fuel return kit with hoses from Amazon for £27, certainly worth it and it fitted perfectly and all is well again. The van appears quieter and smoother now
Jeanclaudedamnvan
Postby OfficiallyColin » Sun Jun 30, 2024 7:00 pm
Had some welding done and the underbody treated recently so while the van was stripped I spend the day cleaning up the floor. Got all the glue cleaned, sorted a few spots of surface rust and then painted the floor. Needs another coat tomorrow but I’m surprised my little Dewalt drill did t catch fire with all the wire brushing it was doing today.
I have no idea what the hell I’m doing.
2006 MK7 115 T350L
OfficiallyColin
