What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Mon Mar 10, 2025 10:02 pm
ned wrote:
loot wrote:Isn't getting older sh*t :roll: foofing about with a £40 radio and I loosely plugged it in and it came to life :P no antenna so I played with settings, but there's no sound so I thought that guy on fb sold me a dud, reeling about how my life sucks etc and about 20mins I plugged the original stereo in and it suddenly dawned on me............ Dick!
:lol:
Where did you acquire your new cills from? And are they decent quality, my fanny has a hole in the passenger door cill so need to purchase some parts
Ebay some are painted black and others galvanised. I've had some from central panels which seem ok. On the swb it's only the sld cill and the front is the cill and full wheel arch. You can buy a cill repair panel which requires that you cut yours up and weld the panel on top, but you have to be creative.
Ids map here
loot
Postby ned » Tue Mar 11, 2025 8:40 am
loot wrote:
:lol:
Aye I got the front wings from central panels but there starting to rust already, I saw some galvanised from bison at a good price but dubious of welding galv, I need to really look and see how much needs doing, might be worth buying the full cill set and inner arches for both sides just wondered if the ones you got were decent quality as I don’t want to do it again in three years
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Wed Mar 12, 2025 12:46 pm
ned wrote:
loot wrote:[qute="ned"]
:lol:
Aye I got the front wings from central panels but there starting to rust already, I saw some galvanised from bison at a good price but dubious of welding galv, I need to really look and see how much needs doing, might be worth buying the full cill set and inner arches for both sides just wondered if the ones you got were decent quality as I don’t want to do it again in three years[/quote]
Galvanised isn't really that,it weld normally with my gas mig. I think it is just sprayed on galv.
The trick is to spray some spot weld spray on the faces of where the panel is welded. Alu zinc spray which you can weld spots through but around them stays, it takes 300c so the idea is it keeps around the spot painted. But be warned you have to make sure that you catch the second panel through the hole or you do a lovely spot weld but a nice ping and a gap between the panels :shock: side tip so the odd edge weld every inch or so. I use sanding flap disks to clean the heads up and more alu zink spray. But I'm inside. If you're outside you don't want to let it get wet on metal as it'll rot
Ids map here
loot
Postby DanMK7uk » Sat Mar 15, 2025 11:45 am
New windscreen yesterday
New battery and tyres done this week too.
New replacement rear light lenses as faded and cracked on one side.
Full service to do today
Hopefully nothing else for a while..
700 odd quid done this week lol
DanMK7uk
Postby M3Stig » Thu Mar 20, 2025 5:50 pm
went all out on the old girl
new timing chain £800
new bottom pulley £330
dpf cleaned out £400
new exhaust sensor 2 £205
sprayed off some lovely orange spots starting to appear on the arches, why can nobody make a decent van that doesnt bloody rust
M3Stig
Postby Redvee » Fri Mar 21, 2025 12:10 am
Expensive week for my camper, last week a new fridge as the old one gave up the ghost and melted the plug, Bought a new one from Helfrauds only to find they've made it slightly bigger than the old one, only an extran 10mm but when it's going into a location built around the old one it's an issue. Got over the length by taking the wheels off the bottom, the width works but still needs to be addressed once we get back from the weekend away. Helfrauds also had the honour of putting two new front tyres on the van outside the house, the NS was on the limit so overdue TBH but they'll give us several years of life based on the 12,000 miles we've done in 2 years of owning it.
Redvee
Postby van_man » Fri Mar 21, 2025 1:18 am
I fitted train air horns to my van last night, lol.
Got a compressor and air tank under the floor, just behind the driver, the air horns are under the front bumper.
I need to wire up the relay and connect the air line and gauge to the dash somewhere, but I will amuse myself greatly honking 140db at unsuspecting pedestrians crossing the road haha
The air on board will definitely be handy though, airing up tyres, blowing down things, inflating ballons etc.
2001 Transit, MK6. 2.4L manual, RWD, Mid roof, MWB
van_man
Postby ned » Fri Mar 21, 2025 8:50 am
van_man wrote:I fitted train air horns to my van last night, lol.
Good aren’t they we shall have to have a honk off with you, gcm and myself, planning on fitting my air tank this weekend and the new bigger horns to the roof to replace the old ones, have you wired your compressor to ignition on or switched on the dash
ned
Postby van_man » Fri Mar 21, 2025 11:29 pm
just a couple of horny van owners haha
The compressor is powered directly from the battery, its 'live' at all times.
The activation relay has an override switch in the rear, so I can turn it on at any time if I'm in the back, otherwise the relay is activated by a switch powered from acc.
The horn solenoid is powered by acc, so the van at least has to be switched on for the horn to work.
It's not on at all times when the van is powered, I still need to manually charge up the tank, this prevents the compressor from running when not needed.
It holds air very well, almost no leakdown, so unless I'm sitting on the horn a lot, it won't need to be charged up often.
van_man
Postby van_man » Mon Mar 24, 2025 1:35 am
Thought I'd add the wiring diagram here, it might be handy for someone else.
It's just a simple 2 relay setup, with a power override switch.
I put the override switch in the rear near my air line fitting, so if I'm in the back working I can charge the tank without needing to switch the van on.
Once I set up the extra battery, I'll pull the power feed from that instead, so I don't risk flattening my starting battery.
The pressure switch is on the air tank, if it's under rated pressure, its n/c, allowing the circuit to operate. once the air tank reaches pressure, it'll automatically shut off the compressor, regardless if the override is on.
The fuse I used is a 30A self resetting unit. The fuse, Relay 1 and wiring should be sized appropriately for the expected draw of the compressor.
Edit, Actually just noticed the error in my diagram, the horn relay (R2) should pull its power to Pin85/87 from the ACC feed, not the 30A Batt+ feed, otherwise the air horns can be activated at any time, not just when the van is on...
van_man
Postby Redvee » Tue Mar 25, 2025 11:45 pm
Spent four days of the weekend away in the van at a campsite just chilling. A couple of jobs needed doing, nothing major, one was swapping the broken heater vent on the neaside where I sit with the one in the middle of the dash where the phone/satnav holder is attached to, job done in 10 minutes once I removed the phone mount and refitted it. I wanrted to hide the poswe cable for the dashcam under the trim but the cable I took was only 2m and didn't reach so I'll attempt it again with the 3m cable. When getting the awning pout I broke one of the joints, a quick google found a supplier not too far off the journey home so called in and as it was a small one man band operation he had a quick look at the broken part and said you only need y part instead of x part that I'd ordered and in doing so I saved £20.
Redvee
Postby P-B » Tue Apr 01, 2025 6:31 am
Tried to code my injectors and get it running right but failed
P-B
Postby loot » Thu Apr 03, 2025 2:28 pm
P-B wrote:Tried to code my injectors and get it running right but failed
Should run ok without them coded.
Ids map here
loot
Postby van_man » Fri Apr 04, 2025 6:22 am
I did one wheel bearing, took all day.
lol.
I guess I'll do the other one on Sunday, I reckon the otherside will probably be a massive pain in the ass too.
van_man
Postby Airthies » Sun Apr 06, 2025 6:04 pm
Used mine as an engine crane to remove a 2.2 from a Mk8 in the gravel compound to put into our new Mk8 jumbo which is in the workshop. ImageImage
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
