What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Wed Aug 27, 2025 9:16 am
ned wrote:Did a little bit more of the stretchy carpet stuff, need to order more for the drivers door and get some matt black plastic paint for the door grab/window switch and door handle
I think anthracite is nice 8) I'm just worried about stock sweets and people having it and ripping it. Rhumblebee many moons ago had good all flocked with a tougher material. I don't know what ever became of the van though yellow mk7 gas van transit.
Ids map here
loot
Postby Harvy » Wed Aug 27, 2025 11:58 am
ned wrote:
That looks very nice! Which stuff did you buy. I want to get some and have been told you get what you pay for. YouTube recommended Harrison trim supplies. They could have been sponsored though… :lol:
I used this stuff off eBay, 3x2m was £20 it’s seems ok for the price baring in mind my vans a work van so probably going to get paint or something on it so didn’t want to spend a fortune
That seems reasonable and for that price I can buy some, try it and if it works out get more later. My sound deadening and insulation should be arriving at home today so I need to deal with that first.
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Postby conrod » Sun Sep 07, 2025 7:14 am
tested new sound system today! Found a JVC head unit that required minimal trimming of the fascia to fit into the odd sized stereo hole on my Mk6. lots of gluing of little brackets with epoxy behind the panel to hold the whole lot in. etc Bought some JBL speakers that were almost a direct fit into the doors - these required an 8mm spacer as the much larger magnets fouled the window regulator. Ran the USB cord from the stereo into the blank plug below the stereo so I can plug my phone in. Reversing camera is also fitted, as this is a campervan with a large box body with terrible rear vision. Now it has the same tech (almost!) as my 2018 Custom :)
conrod
Postby JRHartley » Tue Sep 09, 2025 11:07 pm
Completed the work on my high Top MWB 2.4tdi, it was at a good price as it would not run for more than a few minutes before cutting out. So I replaced the fuel pump with a one wire Bosch VE pump. It now has from the dash adjustable boost & fueling. It needed a little welding at the back but Im very happy with it, returns about 30mpg .
Having a double row timing chain & the one wire pump, reliability worries I dont have!.
JRHartley
Postby loot » Wed Sep 10, 2025 11:24 am
JRHartley wrote:Completed the work on my high Top MWB 2.4tdi, it was at a good price as it would not run for more than a few minutes before cutting out. So I replaced the fuel pump with a one wire Bosch VE pump. It now has from the dash adjustable boost & fueling. It needed a little welding at the back but Im very happy with it, returns about 30mpg .
It'll be a mk6 pre 2006 then I guess. Have had mixed results from the mechanical pumps. But sounds good
Ids map here
loot
Postby JRHartley » Wed Sep 10, 2025 7:48 pm
Yes it is, I found that a little time spent getting the timing correct made all the difference as you know its not a case of moving the pump back or forth.
A EGT gauge is a must have & BTW Im running a 300tdi pump the stock fuel pin was too lean, I fitted an aftermarket pin with a steep ramp & that is spot on.
JRHartley
Postby ned » Sun Sep 21, 2025 3:02 pm
New shiny sliders fitted to the brakes old ones were a bit gunked up
The bloody monkey snot lube has made my hands feel funny, hopefully the squealing pig noise has now gone
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ogri » Tue Sep 23, 2025 8:46 pm
undid and cleaned up/bolted back the drivers seat base earth strap on my 16 year old 234000 mile fwd mk7, having read your posts about it...so far it seems to have cured the intermittent starting fault :shock: i guess tomorrow will tell :D
ogri
Postby Airthies » Fri Sep 26, 2025 7:46 am
Not specifically my Mk7 but have fitted what I believe to be the first air locker diff lock to a Mk7 rear axle
Took a bit of effort as it's not as "on paper" specs might suggest, a straight swap.
But it fits and locks. Though the real test will be once it's installed along with it's matching front locking ranger diff and is put to work out in the wild ImageImage
Sent from my Pixel 8a using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Fri Sep 26, 2025 11:09 am
You're paving the way there Iain 8)
I've a slightly low tech question.
Cutting 4in holes in the front bumper, ok or naff? Anyone done it?
Ids map here
loot
Postby Airthies » Fri Sep 26, 2025 5:21 pm
loot wrote:You're paving the way there Iain 8)
Guess it depends where and how and what for. But in general I don't see a problem they're only plastic
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Sep 28, 2025 8:44 pm
I've got 4in halo led indicator fog lamps to go in :P
Ids map here
loot
Postby Redvee » Tue Sep 30, 2025 12:21 am
Yesterday, tidied up the exposed end of the panelling on the side of the van, several sheets of cardboard, some 3mm ply off cuts and black 4way stretch carpet later.
Redvee
Postby ned » Sat Nov 22, 2025 11:01 am
Fitted a new cab floor mat, might keep it a bit warmer and quieter now
ned
Postby gotgcoalman » Sat Nov 22, 2025 2:13 pm
ned wrote:Fitted a new cab floor mat, might keep it a bit warmer and quieter now
Well done ned.
Out of sight and all that.
Sent from my LE2101 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
