Odour and pollen filter MK7
Re: Odour and pollen filter MK7
Postby Mike » Tue Jan 17, 2012 10:39 pm
Perrys internal codes?
Mike
Wind up merchant!
Postby Frag » Tue Jan 17, 2012 10:46 pm
Yeah,must be.
I can`t find any pollen filters on ford parts online,have you looked at filter for any ford branding or part number ??
Frag
Ford Technician
Postby Mike » Tue Jan 17, 2012 10:52 pm
Mike
Wind up merchant!
Postby Frag » Tue Jan 17, 2012 10:58 pm
Looks like Genuine Ford, 6c11 is a part number,and 1745605 also,usually prefixed with an F
Internet search draws a blank on both,i need access to E-cat at work.
First one i`ve ever seen.
Frag
Ford Technician
Postby Mike » Wed Jan 18, 2012 6:47 pm
Pollen filter now removed as it caused a vibration through the front of the van at motorway speeds :shock:
Mike
Wind up merchant!
Postby Frag » Wed Jan 18, 2012 6:55 pm
Mike Spence wrote:Pollen filter now removed as it caused a vibration through the front of the van at motorway speeds :shock:
Sure it is pollen filter ?
Done loads where the rubber seal that goes across scuttle panel is only pushed onto plastic panel,not both the plastic and the metal scuttle panel.
Sounds like wipers/screen a rattling at 60/70 mph ++++ :o
Frag
Ford Technician
Postby Mike » Wed Jan 18, 2012 6:57 pm
Yep, it started on the M25 this morn, I stopped, took it out and hey presto noise gone. The rubber is glued on as it used to come off, never made a noise though.
Mike
Wind up merchant!
Postby stephenferguson » Wed Jan 18, 2012 9:37 pm
i was wanting to install one, dont suppose you want to sell it mike? Would be great if you could get the ford part number coconut...
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby Mike » Wed Jan 18, 2012 10:05 pm
Frag was going to check out the numbers on eCat, so he may post the number up when he's got it.
Mike
Wind up merchant!
Postby stephenferguson » Thu Jan 19, 2012 10:04 am
I'll try and go into frauds this morn and show them the pic with the numbers on see what they same, if ive got time
stephenferguson
Postby Frag » Thu Jan 19, 2012 8:00 pm
Had a quick look today at part numbers,found 4 that seem to be listed for MK7;
F1745605 odour filter upto 8/06,
F1745604 pollen filter upto 8/06,
F1748749 odour filter 7/8 2006 onwards,
F1748480 pollen filter 7/8 2006 onwards.
Its upto you to confirm these as being correct for your van,i am NOT a parts person :)
As for the service point of view,whether on 15K or 20k intervals
15/20k pollen/odour filter,install if requested
30/40k Pollen/odour filter,renew if applicable
Frag
Ford Technician
Postby Mike » Thu Jan 19, 2012 8:05 pm
So they've fitted an odour filter for an up to 08/06 to my 2010 van.
Mike
Wind up merchant!
Postby Altransit » Thu Jan 19, 2012 8:08 pm
I was under the impression, that an odour/pollen filter was the same thing, so why the different part numbers :?
Postby Frag » Thu Jan 19, 2012 8:12 pm
Mike Spence wrote:So they've fitted an odour filter for an up to 08/06 to my 2010 van.
I honestly don`t know what difference is in age of van,the air intake housing it fits in all look the same to me ........ :?
I checked they weren`t listed for mk6 which is a totally different shape and size.They have a completely different part number.
Frag
Ford Technician
Postby Mike » Thu Jan 19, 2012 8:14 pm
Thanks Frag.
Has anyone got any x ref for these to see what else they fit?
Mike
Wind up merchant!
