TriumphStag wrote:That is the correct connector. I ended up just cutting the connector off, testing each wire to see what it was and then soldering and heat shrinking it to the corresponding wire in the towbar loom. would have been better to use the connector but I did not have time to source one.
Not particularly helpful for your question, but at least you know it is OK to cut and solder.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
