Oil pump recall
Re: Oil pump recall
Postby ake » Fri Sep 09, 2016 7:17 am
Taxistu wrote:Had my letter through. Vehicle just out of warranty. Transit Tourneo mk7 2.2. 3-4 hours they reckon. Does this mean free oil change then??
Yes
Re: Oil pump recall
Postby Digrizrat » Fri Sep 09, 2016 9:10 am
andrusl wrote:Model/Variant Assembly Plant Affected Build Periods (inclusive dates)
Transit -- Kocaeli from 1/10/2011 to 4/10/2013
3S549 - Transit Puma Oil Pump
Affected vehicles will be identified on OASIS. This Service Program is limited to only those vehicles that have been identified as high mileage usage / or with specific drive cycle conditions, within the build range shown below.
ETIS is telling me I'm not affected, checked right now, but I think I'm a euro5 engine in the date range
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Frozen White
VIN Number: WF0XXXTTFXCT15075
Registration Number: YT13JVM
First Registration Date: 14.03.2013
Registration Country: GB
Outstanding Field Service Actions
No Campaign Message(s) found
Is http://www.etis.ford.com up to date? Should I talk to a dealer to check for this? I've heard a lot of bad stuff about the oil pump from you guys on the forum.
Digrizrat
Re: Oil pump recall
Postby walt1984 » Fri Sep 09, 2016 9:51 am
Check with ford dealer dosent cost out for piece of mind, maybe see if they will do a print out to show its not effected.
Yours is a 13 plate different pumps might of been fitted at factory.
Sent from my P330X using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Re: Oil pump recall
Postby Digrizrat » Fri Sep 09, 2016 11:38 am
walt1984 wrote:Check with ford dealer dosent cost out for piece of mind, maybe see if they will do a print out to show its not effected.
Dealer claims I'm not affected... guess there's not much else to do.
Digrizrat
Re: Oil pump recall
Postby walt1984 » Fri Sep 09, 2016 11:46 am
Your build date is December 12.
Mines November 11 and a euro 5 and was recalled. Could yours have been done before hand over?
walt1984
Re: Oil pump recall
Postby bambi mk 1 » Fri Sep 09, 2016 4:12 pm
Ask the dealer to put it in writing :wink:
bambi mk 1
Re: Oil pump recall
Postby ake » Fri Sep 09, 2016 10:43 pm
Have you owned this vehicle from new?
Has it been repaired before you owned it?
Re: Oil pump recall
Postby Digrizrat » Sat Sep 10, 2016 8:11 am
ake wrote:Have you owned this vehicle from new?
No, I bought it about 2 months ago, fully serviced before I got it. How long has the oil pump recall been active? I got the impression it was new.
Sent from my Nexus 5X using Tapatalk
Digrizrat
Re: Oil pump recall
Postby v8dave » Sat Sep 10, 2016 9:00 am
Given this thread was started two years ago by someone knowledgeable I'd suggest the recall has been out for two years.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: Oil pump recall
Postby ake » Sat Sep 10, 2016 9:41 am
Yours will have been done, they started with the oldest vans, ours were done June/July 2014
