loot34 wrote:I never use the handbrake unless I'm on the steepest of hills, i drove up the hill stopped in gear, brake and clutch in out in out and moved off thinking ah f*ckit
loot34 wrote:No dice
Installed software for a later van.
Tried calibrating logitudinal sensor-routine failed.
Tried calibrating abs or something-failed
Calibrated steering angle sensor-success.
Downloaded vin data thing- success.
When it fails it is checking abs, the abs pump makes a noise, identical to bleed master.
It has to be a different abs pump/module as there's nothing else i can think ofCan the yaw sensor be different?
Might just smash the hsa led so it stops winking at me when i start the vandon't think it's worth replacing the abs pump.
Only other thing is that the vcm clone isn't capable of doing the process?
Bummer
loot34 wrote:If i have a 2007 abs module then surely it'll be programmed without hsa? Can anyone say whether i can install abs data? And for a later calibration? Or will it have had the only available update for my van?
I wonder if it is just abs module data or is there extra components on the pump/system?
Walt mentioned an extra solenoid but it isn't listed in my diagram
Would be cool to get to the bottom of this but if Paul doesn't find anything then just short of me pinching a van and striping it then I'm not sure lol
loot34 wrote:OK thanks
Think I'm going to have to do some drastic modification if i want hsa then.
Not going to be cost affective i think.
walt1984 wrote:Ours is a 61 and has hill start. Can't be turned on/off like connect.
57 plate didn't have it. Thing I noticed between the 2 vans, there is something like a solenoid on a brake pipe running down bulkhead under the servo. I don't know if itss any use ill post u a pic.
