Mk7 remote key fob programming/pairing
Re: Mk7 remote key fob programming/pairing
Postby tibsy » Mon Nov 09, 2015 9:42 pm
ok, i`ll see if my "home" laptop (when its in the van/street) will pick up wifi from the house. If not i`ll use the mobile. my VCM has its own laptop (i don`t connect it to internet for any thing else other than win 7 updates) . :)
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby Surfunitone » Mon Nov 09, 2015 9:43 pm
I had my keys reprogrammed at a place in Southend, they erased All according to my van it had 5 keys programmed.. So they erased them and added to my original fob and the replacement fob
2.2 Duratorq-TDCi (110PS)
Surfunitone
Postby loot » Mon Nov 09, 2015 9:46 pm
Ids gives you the outcode and you go to autokeyprog and enter your outcode then calculate the incode and then you manually type in the incode to ids to gain access :-) you don't need your ids laptop to be online, you do need to be online to get the code calculated, i use my phone and it's easy so you'll be fine. 8)
Ps. If there's more known keys programmed, than the actual keys you own then it is a good idea to remove all keys and program the ones you have. :-)
Ids map here
loot
Postby tibsy » Mon Nov 09, 2015 9:57 pm
how long roughly from "ids" giving you an "outcode" do you get before the "incode" has to be obtained and entered?
tibsy
Postby loot » Mon Nov 09, 2015 10:00 pm
At a guess, til your battery goes flat :lol:
You get the code and it doesn't do anything until you click on the next page :-)(but you'll have scampered into the hoos to get the code etc by then :-))
Ids map here
loot
Postby paul2012 » Mon Nov 09, 2015 10:02 pm
Loot.
I have a incode calculator which works with clone VCM's if you want :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby loot » Mon Nov 09, 2015 10:03 pm
Do you? Last i checked was those little red things with tokens? :-)
Ids map here
loot
Postby paul2012 » Mon Nov 09, 2015 10:04 pm
loot wrote:Do you? Last i checked was those little red things with tokens? :-)
This one don't need tokens, it's free :mrgreen:
paul2012
Postby tibsy » Mon Nov 09, 2015 10:05 pm
loot wrote:At a guess, til your battery goes flat :lol:
ok, :lol:
i`ll give it a shot tomorrow :!:
tibsy
Postby loot » Mon Nov 09, 2015 10:07 pm
Is it just a calculator then or dongle? :-)
Ids map here
loot
Postby paul2012 » Mon Nov 09, 2015 10:08 pm
It's a calculator :wink:
I've uploaded it here :arrow: https://www.sendspace.com/file/aqw5wc
Works with Clone VCM's only.
paul2012
Postby loot » Mon Nov 09, 2015 11:50 pm
Cheers Paul :-)
Does it work on Ford only vcm2 ?
Instructions explain for Ford/mazda fly clones.
Be handy if that website ever closes :-)
Ids map here
loot
Postby paul2012 » Tue Nov 10, 2015 6:22 am
loot wrote:Cheers Paul :-)
It works on the clone VCM's, but not VCMII's.
paul2012
Postby tibsy » Tue Nov 10, 2015 3:39 pm
calling loot,
just hooked it up and got the following as an outcode-
0040 0****F 000000
when you go to auto prog-you get-
outcode type-(single or dual) which is it??
then
outcode value- there are 2 boxes (the 1st box will only accept max 6 digits)
no matter how i try to enter the outcode -i can`t! :(
tibsy
Postby tibsy » Tue Nov 10, 2015 3:46 pm
i think i might have solved it- its just the 0****F that i need to enter-right :?:
i`ll wait for someone to confirm before i try again!
update-
SORTED :D
tibsy
