Bonnet release
Re: Bonnet release
Postby Captain chaos » Fri May 27, 2022 9:54 am
I finally managed to get back on this and nothing would move , won't budge so am I trying to do the correct thing? I used this to try and turn where the groves are and it quite a good fit
Some closer pics
Captain chaos
Re: Bonnet release
Postby Captain chaos » Fri May 27, 2022 9:58 am
Captain chaos
Re: Bonnet release
Postby ned » Fri May 27, 2022 9:59 am
Can you see up to where it latches onto the bonnet?
If you can maybe it’s worth undoing the 2 10mm (I think) bolts thus detaching the part from the bonnet allowing you to open it, if that makes sense.
The other option is to cut through the entire thing with an angle grinder (being careful of the rad) if your doing away with it anyway you maybe able to access the inner parts to release the latch.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Bonnet release
Postby Captain chaos » Fri May 27, 2022 10:19 am
I can't see the latch or bolts, I can feel the latch ring but can't seeit
Captain chaos
Re: Bonnet release
Postby knobby1 » Fri May 27, 2022 9:35 pm
Captain chaos wrote:I can't see the latch or bolts, I can feel the latch ring but can't seeit
Looks like it's been living at the bottom of the ocean, well rusted for sure. I dont envy you.
Re: Bonnet release
Postby Captain chaos » Tue Jun 14, 2022 6:48 pm
so, ive got back to this (finally) and the square plate in the pic is actually the front of the lock
it seems there may be more than one sort of lock
this one
and this one with just a square lock body on the front
i had the latter, this on ebay shows the two, one with a front fitting and one with just a square
https://www.ebay.co.uk/itm/185237814864 ... SwwrRhz0G3
so mine was just the square which is held in place with a bolt that goes through the u shaped cutouts in the top. judging by the damage someone had already tried to get to the bolt, and although i could see and feel the bolt and could get to it with a spanner i decided against trying to get it out as even if i undone it i still couldn't get to punch it out
so i used a HSCO drill bit through the center, 9mm , went through like butter. being careful with progress it just touched the bit on the back that turns (the bit the lock turns in the catch) and the bonnet popped up. stopped drilling and in with a screw driver to turn clockwise and it was released
Captain chaos
