knobby1 wrote:Yz Garry wrote:I have changed leak off seals checked fuel filter housing for cracks can’t see any checked all fuel lines round engine can’t see anything losing the will to live now.
You won't see any air leaks and fuel doesn't leak out as the system is under a slight vacuum when the engine is running, there in no pressure in the inlet side of the fuel system on a Euro-4, they don't have an "in-tank pump" like the Euro-5's.
Kopon wrote:knobby1 wrote:Yz Garry wrote:I have changed leak off seals checked fuel filter housing for cracks can’t see any checked all fuel lines round engine can’t see anything losing the will to live now.
Just returning to this thread as it's the most relevant for me. In my case, the hot start problem appears to have been fairly well resolved by replacing the starter. I'm not sure if it reduced the current draw or perhaps increased the cranking speed but, either way, hot start is greatly improved. However, I'm now concentrating on poor cold starting, mainly due to only driving the van at weekends and finding a half full fuel filter.
Knobby, your understanding of the fuel system for the Euro4 is what intrigues me. Can you explain why the fuel system is under a slight vacuum when the engine is running? Isn't there a mechanical lift pump to suck fuel from the tank = vacuum ok. But, thereafter the fuel is pushed to the filter and on to the HP pump = pressure? Or is the HP pump drawing the fuel from the tank via the filter? Anyway, I'm struggling to understand how air ingress would deplete the contents of the filter regardless of the source or location of the defective part.
Thanks.
Kopon wrote:OK.
But I can't get my head around how the syphoning can happen as none of the pipes attached to the filter head actually protrude into the filter body? When I remove the filter the fuel level in it can be around half full which is a complete mystery to me.
In another thread I have posted some images of live Forscan data showing extremely high FRP, (92000 kPa & 93750 desired at 3781 rpm) I'm now wondering if some of this pressure could escape back through the system and possibly force fuel out of the filter. Just a thought.
So just to clarify:
There is no LP pump in the tank and no mechanical lift pump on the engine?
T350camper wrote:Knobby is bang-on with his description that you should think of the filter as one of the inlet pipes (which it is). If there is the slightest imperfection between the filter seal and housing, you would think it should leak fuel, but due to the slight depression it tends not to and the system self bleeds minor air bubbles as you drive. But when you switch off and the mechanical pump on the engine stops, then gravity takes over. Air weeps into the filter and the heavier fuel makes its way back to the tank.
Kopon wrote:Yes, I get that now. Thanks.
The rubber seal on the filter is what effectively makes it become part of the feed pipe so, to all intents and purposes, it's just like a large bulge on the pipe. That being the case, I guess the drain back is more likely to be via the feed pipe rather than the return pipe?
Users browsing this forum: Kimmo, PWRR-TRANSIT
