Timing Chain Replacement
Re: Timing Chain Replacement
Postby metalworker0 » Sat Jul 25, 2026 1:40 pm
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
when you put its part number into ebay - 1470854 - it comes up as one for the gearbox for some unknown reason .. must be the same
18mm
why did you take it out ?
Postby Smelly Dog » Mon Sep 07, 2026 6:53 pm
Thanks metalworker. All back together and running ok. Is there any real risk having a bolt and some sealant in the freeze plug hole?
Smelly Dog
Postby metalworker0 » Mon Sep 07, 2026 7:05 pm
i don't know which one you're talking about
if into crankcase no risk
if into cooling jacket .. then its sometimes at 15 psi of pressure
if its at the end of an oil gallery - then you have 40 psi or more of pressure
Postby Smelly Dog » Mon Sep 07, 2026 7:06 pm
It's the one about 10 o'clock on the timing chain cover... A couple of inches in from the left side.
Smelly Dog
Postby metalworker0 » Mon Sep 07, 2026 7:24 pm
The clues are not good enough unless you are looking at the engine upside down
in the plastic cover you say .. why would you have a freeze plug in a tin cover
is it this
https://www.ebay.co.uk/itm/194868118844?
all the best ..mark
Postby Smelly Dog » Mon Sep 07, 2026 7:57 pm
Smelly Dog
Postby metalworker0 » Mon Sep 07, 2026 8:32 pm
Smelly Dog wrote:Think it is this one:
https://www.ebay.co.uk/itm/266498971470 ... bt-GC84Q38
mk3?
Postby andz327 » Thu Sep 10, 2026 11:10 am
andz327
