the van is out of warranty so did the job myself,the valve cost me £95 off the tinternet.
Now back to my findings-the socket on the top has 5 pins three in a row(these are the sensor wires) , plus two(these are the power)apply 12volts too the power pair the valve will open ,swap the pair the valve will close'if you are lucky'
i have removed cover of egr to find lots of carbon caked over everything (me thinks the valve seal failed cloging the lot up ) lots and lots of wd40 ,just a waiting game now.
So to sum up the sensor wires offer a resistance (ohms) the ecu see's this and can tell where the valve is ,ie open or closed or some where in between. So if your valve is stuck like mine and the ecu tells the valve to close or open, the 'resistance '(electrically speaking ) will stay the same(because the valve has not moved). the ecu see's this and can see the valve has gone faulty ,then lights the engine man light and ford gets abit more of your hard earned cash .SO unplugging the egr electrical connector is basically one of the same thing.Plugging a working egr valve back in will remove the light ,to all of you with the light still lit ,you have another fault or a fautly erg valve (yes i know the bloke who you got it off ,said it was working ? ha ha )he would !
