tddi argh! advice please (finished 26/3/10) Thank you FTF
Re: tddi argh! advice please
Postby angeleye » Mon Mar 08, 2010 12:41 pm
yes thru injector holes tester should have instructions, it will run as good as new im sure when you have finished, you will get a slight variation on compression between each cylinder,what the variation allowance is i cant remember on your engine, or what compression you should have ,sure winterheating ,or one of the techs will advise
angeleye
Postby belly » Mon Mar 08, 2010 10:55 pm
Dropped the tddi injectors off today to get reconned :D just got to get a nice bottle of red for my mate 8) as for the cover i've already ordered one now so might aswell use it, old one was letting the front down anyway as i put new pulleys tensioner and belt as a matter of course on my transits :lol:
belly
Kaiser Chief
Postby belly » Sat Mar 13, 2010 8:56 pm
Quick update, had a spare couple of hours this afty so got it built and timed back up to do the compression test! pots 12&3 all came in at 30bar is that ok? but pot 4 came in at nadda zilcho fook all :( :lol: oh well suppose i was expecting a bit much, starting earlier to get work done tommorrow so hopefully i will be able to get the head off in the afty i've already stripped most of it back down and got the cams out :)
belly
Kaiser Chief
Re: tddi argh! advice please damage pics update 14/3/10
Postby belly » Sun Mar 14, 2010 10:32 pm
Finally got the head off today! all fairly straightforward :) and upon closer inspection in the daylight with the cams and carrier off it was as suggested by AK
AK wrote:My 54 plate tddi 115ps one managed to snap a valve spring and it sounded just like you have explained, could be wroth checking the valve springs
one of the inlet valve springs had snapped causing the valve to drop :(
Hmm that spring looks funny!
that will be why then :x
Dropped valve!
marked piston! doesn't appear to have any damage though!
Valve in question! appears straight and didn't stick at all
thank god it's a lwb :lol:
and i've had an idea :wink:
only joking :lol:
so what do you guys reckon?
1 should i replace all the valve springs?
2 should i replace the valve?
3 i'm also thinking of doing the valve stem seals also whilst it's off, is there anything else i should do whilst the heads off?
4 are the headbolts stretchbolts?
all advice and pointers welcomed cheers guys :D
belly
Kaiser Chief
Postby winterheating » Sun Mar 14, 2010 10:42 pm
the engine sitting for so long may have had something to do with spring breaking, why dont you just price up a full set of valve springs and valvestem oil seals. :?:
whats the mark on the other inlet spring :?:
i think you should be able to get 1 valve for about £20 for the sake of it, it will, and has by the looks of it been spinning round hitting piston so may have made the edges weaker still.
winterheating
Postby belly » Sun Mar 14, 2010 10:49 pm
winterheating wrote:the engine sitting for so long may have had something to do with spring breaking, why dont you just price up a full set of valve springs and valvestem oil seals. :?:
Thats what i thought tbh maybe the springs had gone brittle weak etc etc! that mark is a mixture of oil/bad light/i phone camera! i saw exactly the same thing and thought wtf is that! checked it and cleaned it off all and it's ok :) cheers winterheating 8) think i'm just going to do the lot i've always tried to do things like that as its a false economy not to :wink:
belly
Kaiser Chief
Re: tddi argh! advice please (updated with damage pics 14/3/10)
Postby winterheating » Sun Mar 14, 2010 10:52 pm
whats the rusty water marks from thats all over :?:
winterheating
Postby belly » Sun Mar 14, 2010 11:07 pm
winterheating wrote:whats the rusty water marks from thats all over :?:
Whereabouts? which pic?
belly
Kaiser Chief
Postby winterheating » Sun Mar 14, 2010 11:10 pm
first pic all over bulkhead, and on side of cam carrier thats laid on your nice new ply floor.
winterheating
Postby winterheating » Sun Mar 14, 2010 11:13 pm
i think it would be worth checking piston protusion difference also for peace of mind before head goes back on.
winterheating
Postby belly » Sun Mar 14, 2010 11:17 pm
winterheating wrote:first pic all over bulkhead, and on side of cam carrier thats laid on your nice new ply floor.
winterheating wrote:i think it would be worth checking piston protusion difference also for peace of mind before head goes back on.
Ok fair enough on the bulkhead but cam carrier :shock: hawkeye :lol: believe it or not thats clayish water from how it was treated :x How do i check that? and what you thinking? bent rod? :?
belly
Kaiser Chief
Postby belly » Sun Mar 14, 2010 11:19 pm
oh and the nice floor i know :oops: a little cowboy eh should have covered it really ah well wood likes a good oiling :lol:
belly
Kaiser Chief
Postby winterheating » Sun Mar 14, 2010 11:24 pm
yeah just to double check its not bent slightly, otherwise it would only make piston pickup and wreck the block. :(
winterheating
Postby belly » Sun Mar 14, 2010 11:30 pm
ok cheers i will swot up on how to do it and buy according equipment tools etc :wink: my locking/timing kit is ace as is my new compression tester although i did the compression test with the vac/waterpump not bolted back up and preceeded to replicate the exxon valdise :oops: :lol:
belly
Kaiser Chief
Postby coconut » Mon Mar 15, 2010 12:14 am
I'd pretty much garentee the piston protrosion will be fine with that minor amount of marking to the piston ( seen pistons with much worse damage when the timing has jumped and they have been fine ) :!:
Probably worth changing all the springs, depending on price of course :)
Replace all 10 x 17mm and 8 x 13mm head bolts, 10 rocker shaft bolts and put the same notch head gasket on as you've taken off :wink:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
