How to add factory cruise on a mk7 transit no pics
Re: How to add factory cruise on a mk7 transit+pics
Postby Darren.w » Mon Feb 22, 2016 7:37 am
coacher wrote:
Darren.w wrote:It doesn't lol at it just now
There's a cheap complete one on eBay for 60 quid. I'll buy the back off you if it's in good condition
The back ? Just going to fit the complete new wheel and sell this wheel
Darren.w
Postby coacher » Mon Feb 22, 2016 12:14 pm
How much do you want for your old wheel? I bought one but it didn't come with the back. Can't find one
coacher
Postby mafty » Sun Feb 28, 2016 12:10 am
coacher wrote:How much do you want for your old wheel? I bought one but it didn't come with the back. Can't find one
How about this one?
http://www.ebay.co.uk/itm/-/231859398271?
Di! Ecce hora! Uxor mea me necabit!
mafty
Postby mindaugasa » Thu Apr 07, 2016 8:12 pm
Hi there,
May someone could share bcm calibration file for cruise control (2007 tourneo manual 2,2tdci, if that mater)
Gave the van for local tuners, but they struggle to get required ver file, sorry for them
Thanks!
mindaugasa
Postby ake » Thu Apr 07, 2016 8:28 pm
mindaugasa wrote:Hi there,
Thanks!
The file has to made for your specific vehicle, it can't be shared with some one elses
Postby mindaugasa » Fri Apr 08, 2016 8:02 am
Sorry, dumb, but still want cruise control :)
Is it so, that existing BCM file can not be tweaked to activate cruise control and "template" file must be used - uploaded to the BCM?
mindaugasa
Postby ake » Fri Apr 08, 2016 6:59 pm
mindaugasa wrote:Sorry, dumb, but still want cruise control :)
Correct
Postby mindaugasa » Fri Apr 08, 2016 7:59 pm
Correct
Good. So, how to obtain that "template" file?
Those local tuner talking crap about new-blank BCM required
mindaugasa
Postby ake » Fri Apr 08, 2016 9:43 pm
Correct
Pm MartynX and he will create your file
Postby mindaugasa » Sun Apr 10, 2016 1:56 pm
Thanks, PM sent.
mindaugasa
Postby davyjcb » Mon May 02, 2016 9:47 am
If anyone is interested there's a breakers over here in ni that break vans only I bought a bcm,an ecu the encoder ring c/ 2 keys for 70 plus vat and its plug an play no programming fair enough the identity of the chassis no's is not correct but since nobody seems to have ids over here other than the dealers its a handy way out even the remote fob works forthe Central locking as the pats all match up also got a high spec dash an trip stalk for 30 only prob is the dash was wrong,too early so the rev band was green mid range an not red line from 4 1/2 thou up so some of the icons are missing / in different positions
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby t2myd » Mon May 02, 2016 10:45 am
davyjcb wrote:If anyone is interested there's a breakers over here in ni that break vans only I bought a bcm,an ecu the encoder ring c/ 2 keys for 70 plus vat and its plug an play no programming fair enough the identity of the chassis no's is not correct but since nobody seems to have ids over here other than the dealers its a handy way out even the remote fob works forthe Central locking as the pats all match up also got a high spec dash an trip stalk for 30 only prob is the dash was wrong,too early so the rev band was green mid range an not red line from 4 1/2 thou up so some of the icons are missing / in different positions
So you fit the bcm and your cruise works ?
Transit vantastic !!!!!!
t2myd
Postby davyjcb » Mon May 02, 2016 11:16 am
It still requires the relevant software upgrades by the guys who are smarter than me but it will enable you. to send the bcm away to get done while at the same time you should be able to drive your own van on your own control modules ie no down time ,get the modified kit back from the like of vantuner who can redo all the programmes reset the vin an all the relevant vehicle specific info you get it back it should be plug an play
davyjcb
Postby martynx » Mon May 02, 2016 12:00 pm
Sending me a BCM by post to get cruise activated is quick & simple & many people do .. Send Monday get BCM back Wednesday is typical UK turnaround , or wait till you go on holiday so no downtime :wink:
Using the spare ECU kit is an option but there are some arguments against it..
If dont have access to IDS & decide to go down the road of sourcing a used matching Engine ECU, BCM & Blue Key fob to keep your van mobile whilst cruise is being activated dont send that "spare " kit as many aspects of the configuration cant be changed remotely like injector correction factor data, pump & pilot learn data. Put the spare kit on temporarily while you post your original BCM.. then sell on the kit once done.
Also , its more costly to do programming & hence time wise as I wouldn't be just activating cruise, i'd also be changing VIN, mileage (if clocks are changed as well) ,& any other setup differences like PCM software if axle ratio differs . So its possible just quite involved.
TYMD - If you get a ECU/Key kit from a cruise enabled van but otherwise very similar spec van ( PCM/BCM & Key Fob) then you'll have cruise working , assuming your wiring & steering wheel is in place.. The trick is finding the right spec donor kit 1st , get it a little wrong & your dash display will be just lots of warning lamps & having the the wrong VIN ID may not be to everyone's taste !
martynx
Postby t2myd » Mon May 02, 2016 4:26 pm
Was Easter me coming you Martyn , have you fit the axel to agent orange yet .
t2myd
Users browsing this forum: Parky7
