Idiots guide to IDS
Re: Idiots guide to IDS
Postby seamie » Tue Aug 18, 2015 10:53 pm
Tried installing ids tonight but had no joy :( Will have a better look tomorrow evening when I've more time. I noticed there was no v81 calibrations file with the CD and was hoping someone could link me to it?
seamie
Postby loot » Tue Aug 18, 2015 11:20 pm
V81 dvd should have calibrations unless you mean you don't have that disk?
Ids map here
loot
Postby seamie » Tue Aug 18, 2015 11:58 pm
I don't have the v81 DVD. I received 2 CDs, one for Ford the other for Mazda but neither have the v81 files.
I installed ids 1st time using your instructions rather than the ones that came with the vcm which failed. Thanks for your help Loot man :)
seamie
Postby Airthies » Wed Aug 19, 2015 1:00 am
loot wrote:Possibly but vista is so resource hogging you'll probably need a quad core i22 with 100gb ram
Can't you blag a copy of w7? :-)
Think you can upgrade to w7 if you're running vista (though may depend which version? )
Via Direct download from Microshit support. Was gonna do this myself till I found I'd have to upgrade the ram etc so never bothered.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Aug 19, 2015 7:48 am
I'm pretty sure a machine running vista will run quicker with w7 on, i believe w7 is based on xp but with better resources :wink:
Ids map here
loot
Postby seamie » Wed Aug 19, 2015 6:11 pm
Can anyone link me to v81 calibrations? I seen a post on this forum saying the dvd is about 3.5gb but the only ones I can find are a lot smaller that this
seamie
Postby seamie » Thu Aug 20, 2015 8:04 am
Calibrations sorted :)
When I try to connect to my van I get an error message something along these lines
Unique identifier can not be found
Please check your diagnostic system is up to date.
Has anyone come across something similar?
I've got my hands on a copy of xp that I'll pop on to my laptop tonight and try installing it on that.
seamie
Postby loot » Thu Aug 20, 2015 8:14 am
Try that and maybe try ids on another vehicle just to make sure it is the vcm/software that is at fault.
You need the vehicle ignition in pos 2 dash lights on when connecting ids. :wink:
Ids map here
loot
Postby seamie » Thu Aug 20, 2015 8:59 am
The ignition was on and I successfully connected to the van using the Fsuper after the vcm failed.
Has anyone used ids with VMware? Is there any negatives from using it?
seamie
Postby loot » Thu Aug 20, 2015 10:59 am
Do you have other diagnostic software on the laptop?
You would have xp/7 with updates only and then ids, partition the hdd if you want other software ideally.
You need to make sure that ids is running correctly and that it connects to the vcm workout issue.
Most likely problems are faulty cable or faulty capacitor on the vcm that deals with connections.
Had a quick search but can't find the capacitor fix how too :-(
Ids map here
loot
Postby seamie » Thu Aug 20, 2015 11:14 am
I've a few other bits of software that work with the fsuper I'll try deleting them before I try again.
I plan on partitioning about 40/50gb and installing xp to run ids only.
I'll take a few screenshots of how I'm installing it on xp and of any errors that might pop up when its installed.
seamie
Postby seamie » Fri Aug 21, 2015 6:10 pm
OK so xp for some reason refused to install on my laptop :lol: on currently installing windows 7 ultimate to see if I can get ids and my vcm to work. One thing I've noticed is in a few of the tutorials I've read they say to install v86 of ids but the one that came with my vcm was v86.01A. Has anyone any experience with v86.01A? Is it just the same as earlier versions?
seamie
Postby loot » Fri Aug 21, 2015 6:13 pm
It's an update
Check the file size, if it is 300-500mb then your OK but if it is 25-50mb then it's just the update.
I have v86 and v86.04 update, i doubt i could run direct from the v86.04 tho.
Ids map here
loot
Postby 75psT330lwb » Sat Aug 22, 2015 10:00 am
why has the vcm got a power supply connector :? :?: is there supposed to be a power supply supplied with it :?:
Custom Ecoblue
75psT330lwb
Postby 75psT330lwb » Sat Aug 22, 2015 10:28 am
bit stuck on install. got to "install v84 license" but don't know where that is :? :?: can anyone help please :(
Note from loot it's v86:-(
Custom Ecoblue
75psT330lwb
