Idiots guide to IDS
Re: Idiots guide to IDS
Postby loot » Sat Aug 22, 2015 6:28 pm
8) so you have it all up and running now then? :-)
Ids map here
loot
Postby seamie » Sat Aug 22, 2015 7:12 pm
Yes so far so good, well apart from the countless DTCs :lol:
Managed to preform a PCM update and currently looking into checking the SCV and PRV that I had changed were coded (if thats the right term) to the van
seamie
Postby marjers » Sat Aug 22, 2015 8:18 pm
Just posting this in case anyone else has same problem
my Windows 7 just upgraded to Windows 10 i was realy worried that IDS would not work!!!
BUT IT DOES WORK Thank goodness :D
2010 mk7 2.4 350l rwd 100ps mwb hi-top
Tuned by vantuner 115 eco
marjers
Postby loot » Sat Aug 22, 2015 9:30 pm
Dude that's great news I've got a minime on w8 which doesn't work but I'm in the process of putting 10 in in an attempt to see. 8)
Ids map here
loot
Postby seamie » Sun Aug 23, 2015 6:04 pm
A quick question about calibration files.
I've noticed a few posts, which are a couple of years old now, with v81 calibration files, is this the latest version?
seamie
Postby loot » Sun Aug 23, 2015 6:12 pm
Yes v81 was the last dvd ids available and after that it went online to etis.
You install the c81 calibrations and then any newer ones you get online via etis get saved in the same folder. :-)
Ids map here
loot
Postby seamie » Sun Aug 23, 2015 6:45 pm
loot wrote:Yes v81 was the last dvd ids available and after that it went online to etis.
Ok I'm confused......again :)
How can I download from etis? I've been on the site and entered my vin which brought up my van but I'm unable to download from there. Sorry if this post has gone off topic
seamie
Postby loot » Sun Aug 23, 2015 6:52 pm
What are you trying to download?
Ids map here
loot
Postby seamie » Sun Aug 23, 2015 7:04 pm
loot wrote:What are you trying to download?
Maybe I'm having another one of my blonde moments here but I was hoping to get the latest calibration files.
seamie
Postby loot » Sun Aug 23, 2015 7:15 pm
Just have ids on and Wi-Fi internet and when you go to pcm update it should automatically do it, it'll only get the latest 1 you need for the job you are doing tho, the c81 is all of them for all vehicles upto it's date of mid 2012.
Alternatively you can go to motorcraftservice and try getting it by puttin your pcm tag in buy I've never been able to get it from there except blue estates 1 Lol
Try doing a pcm update in ids first tho.
Beware that it adds anti stall and things but smooths out power delivery which may feel like loss of ps.
Ids map here
loot
Postby seamie » Sun Aug 23, 2015 7:27 pm
Ahh right I get you now :oops: I thought I had to download the latest software for my van onto a pc then add it to the calibrations file :lol:
I preformed a pcm update last night and the laptop had internet access so I guess I have the latest version. I noticed the anti-stall this morning and tbh I don't mind it and the van is running much much better than it ever did but still makes the same noise as a lollipop stick between the spokes of bmx :lol:
Thanks for your help Loot :D
seamie
Postby loot » Sun Aug 23, 2015 7:45 pm
You can do it manually but i never have Lol.
I recommend after a pcm update you should do a pump and injector learn :-)
Also you can get the injector correction factors off connector part of the injectors and go into injector correction factors and see what numbers ate shown in ids and make sure they are the same as yours in the right order.
That should be done first before the learns if you want to check, if not just do the learns.
If you didn't have the van new and there is no paperwork i suggest checking the injectors.:-)
Ids map here
loot
Postby seamie » Sun Aug 23, 2015 8:02 pm
Cheers mate, I'll do this tomorrow. Good to know I don't need to pop the injectors out to check the code on them :D
seamie
Postby seamie » Tue Aug 25, 2015 7:38 pm
Anyone know where to find recordings on ids? I recorded cylinder balances earlier but can't seem to find where they're stored now :)
seamie
Postby loot » Tue Aug 25, 2015 7:42 pm
Not too sure :-(
Did you save the session when you closed it?
I'd go back into that session and look on technician logs
Ids map here
loot
