How to add factory cruise on a mk7 transit no pics
Re: How to add factory cruise on a mk7 transit no pics
Postby vansit1 » Wed Feb 25, 2026 5:03 pm
i just dove into the dash and noticed that i already have the Bcm and all wires preinstalled, so is it somekind of special blank model and what else can i add to it, if it also has some small connector right in the middle of the steering column? :p
vansit1
Postby loot » Sat Feb 28, 2026 6:27 pm
If you want just cruise you only need the 2 orange wires to be present on the steering sqibb 6 o'clock connector. You'll see it if you remove the lower steering cowl.
Then the bcm at cx level on the label.
And the steering wheel with buttons.
And activate it with forscan.
Ids map here
loot
