What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Sat May 18, 2013 8:59 am
Dale1970 wrote:
limitedblack wrote:Shall we start the xenon club ? :lol:
Yah why not :lol: :lol: :lol:
that's what I'm looking for 8)
how 2?
Ids map here
loot
Postby belly » Sat May 18, 2013 9:55 am
Guys can you clarify what units you split ? Are they pattern units or the oe Mako ones ? Cheers 8)
belly
Kaiser Chief
Postby limitedblack » Sat May 18, 2013 10:28 am
Mine are the genuine Mako units, very hard to split as the glue doesn't melt like the pattern units, but I like to do things the hard way. My mate asked me why I do these things, I just said because its hard to do :D
Happy Easter
limitedblack
Postby belly » Sat May 18, 2013 11:40 am
limitedblack wrote:Mine are the genuine Mako units, very hard to split as the glue doesn't melt like the pattern units, but I like to do things the hard way. My mate asked me why I do these things, I just said because its hard to do :D
Yeh they're proper tough ! I gave up as I couldn't get the finish I was happy with :?
belly
Kaiser Chief
Postby blue estate » Sat May 18, 2013 11:41 am
No ! you kept cracking them :wink: :lol: :lol: :lol: :lol:
blue estate
Postby loot » Sat May 18, 2013 12:27 pm
fitted my heated rear Windows switch went to configuration and only had the option of barn doors, with window heater but no rear wash wipe function??
computer says no.
barsteward! manual bodge it is then.
does anybody know what features are on the rear wash wipe? I.e turn them on and they wipe continuously or intermittent? and if I just wire a relay to power them they'll have the return to base switch in?
thanks for any help.
Ids map here
loot
Postby Punto443 » Sat May 18, 2013 1:17 pm
loot34 wrote:fitted my heated rear Windows switch went to configuration and only had the option of barn doors, with window heater but no rear wash wipe function??
computer says no.
Would enabling the heaters not automatically enable a wash wipe too? Or are some fitted with glass and no wiper?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Dale1970 » Sat May 18, 2013 1:27 pm
Mine are the genuine Mako units. as Limited said glue hard to split but put mine in oven at 85c for half an hour and they split quite easy just be patient. Start at the top point and work down both sides and then the bottom. I went round mine with Stanley knife and gradually prised a part with to flat headed screw drivers a bit like removing a bicycle tyre . :wink:
Transit MK7 SWB MID ROOF 85PS 56 PLATE RE MAPPED & EGR Removed
Transit MK6 LWB MID ROOF 75PS 2000 X
Transit MK5 SWB MID ROOF 1996 P
http://www.incarsoundandsecurity.co.uk
Dale1970
Postby loot » Sat May 18, 2013 1:54 pm
computer says no.
it's 2 separate functions rear heated glass, rear wash wipe.I can turn on the heated glass bit it still doesn't work,I think it uses the same relays/ fuses as the mirrors which I couldn't get working either so jumped the feed off the heated screen which I hope I can do independently from it.
the wipers in theory should be easy if it's just power I need to them but I'm hoping when I turn the power off they return to the rest position.
:wink:
Ids map here
loot
Postby RichH » Sat May 18, 2013 2:25 pm
Not much. Been busy.
Replaced blown stop / tail bulb in RH cluster. But crappy spares shop didn't have a bulb for the high level light.
Also while parked on the kerb outside the shop noticed the rear door was hard to open and close like the body was twisted! Does parking on the kerb i.e. loading one wheel twist the body that much??!! :?
http://www.rhdoorsandshutters.co.uk
Automatic door and roller shutter specialists.
RichH
Postby limitedblack » Sat May 18, 2013 2:47 pm
computer says no.
Intermittent when on, auto constant when in reverse and front wiper on.
Happy Easter
limitedblack
Postby loot » Sat May 18, 2013 3:36 pm
computer says no.
:shock: not sure I'll be able to manage that lol can you see any problem with me wiring it to a fuse/ relay/ the stalks and have it on/ off?
thanks.
i could put timer relays and stuff on and link to the reverse light I suppose, I will try to maybe just have it intermittent when on to save over working it.
:wink:
just been in the garage and found an old project, I like the way you think lb.
:o
Ids map here
loot
Postby Dale1970 » Sat May 18, 2013 3:52 pm
Fitted my lights 1 light not working a bit pissed but I am sure they will send new bulb. Also fitted my new twin tail pipe thanks to Limited Black 8)
8) 8) 8)
Dale1970
Postby mark06 » Sat May 18, 2013 3:55 pm
Cossie wrote:
Dale1970 wrote:Sorted lights out carbon wraped and projector Xenons fitted. Going to have fun wiring them :lol:
Thay look awesome mate.
X2 they do look 8) 8) 8)
mark06
Postby limitedblack » Sat May 18, 2013 4:28 pm
loot34 wrote:
computer says no.
thanks.
:wink:
:o
Ahh the old 555 timer chip, most common ic ever made, more than 2 billion sold :o got a few in mine now :)
Happy Easter
limitedblack
