2007 Mk7 appears broken into with no damage
Postby alzee20 » Sun Jul 01, 2012 9:38 pm
Lol, when I had mk5's they all had a spare key cable tied underneath.. Saved money on windows!
Every few months my mate would ring up an ask which one to pop this time :)
mk7 280 115ps swb fwb lr - 20000 miles so far..!
mk6 280 75ps swb fwd lr - Dead but took a sprinter with her! :)
mk6 280 75ps swb fwd lr - Vantunered!
alzee20
Re: 2007 Mk7 appears broken into with no damage
Postby paul. » Sun Jul 01, 2012 10:02 pm
TIMO wrote:doing it this way you must have a second fob programmed and hidden somewhere on the van. mines in the engine bay
Good thinking! Il order one off ebay tomorrow and look for a good hiding place in the engine bay. Could do with crappy jump leads in there somewhere aswell is I can find room :lol: Cheers for that
Mk7 2008 350LWB 2.4 100PS
paul.
Postby loot » Sun Jul 01, 2012 10:19 pm
I may be wrong but can i suggest when you do get the 2nd fob to use it from time to time to keep it in sync and charged.
:D
Ids map here
loot
Postby paul. » Sun Jul 01, 2012 10:50 pm
loot34 wrote:I may be wrong but can i suggest when you do get the 2nd fob to use it from time to time to keep it in sync and charged.
:D
I just found the original second fob that I got with the van buried under the sink. It didnt work when I got it and it knackered looking. Anyway I just re-synced the two of them together there so its working. Id say the second one was out because of low battery so Im gonna pick up two batteries tomorrow and re sync and hide one. Il just re-sync every couple of months to keep them both working. cheers
paul.
Postby loot » Sun Jul 01, 2012 11:26 pm
Result!
I thought they went out of sync because they use rolling codes and eventually the spare 1 goes out of range?
Ids map here
loot
Postby paul. » Sun Jul 01, 2012 11:43 pm
loot34 wrote:Result!
oh, that sounds like it makes sense. Il just use the one under the bonnet once a month so. I cant change between the two because the loop for the keyring is broken off the bandy one. Ah well, at least I dont have to fork out 30 quid for new :D
paul.
Postby IrishChippy » Wed Jul 04, 2012 10:01 pm
Heres what I did to bypass loom problem. Il rerouted it inside the rear pillar to take away any risk. I also removed the locking mechanism.
IrishChippy
Postby Wesleymk8 » Wed Jul 04, 2012 11:40 pm
Can someone Pm me why I need to disconnect the drivers locking barrel from the mechanism. Have a rough Idea but only have 1 fob so not sure if its worth the risk of getting locked out, cheers
Wesleymk8
Postby Grumpy old man » Thu Jul 26, 2012 7:31 pm
This happened to me last night and I know I locked it.
Now I'm looking at a disciplinary from work for equipment stolen because "I left the van unlocked".
Any advice greatly appreciated.
Grumpy old man
Postby Herts » Thu Jul 26, 2012 7:52 pm
Grumpy. PM sent.
Did they drive it away or just nick your tools?
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby Grumpy old man » Thu Jul 26, 2012 8:06 pm
Just some equipment.But the most expensive ones.
Grumpy old man
Postby Herts » Thu Jul 26, 2012 8:40 pm
Do they have insurance?
Andy
Herts
Postby Grumpy old man » Thu Jul 26, 2012 9:02 pm
Not for contents/tools/equipment.
Grumpy old man
Postby alzee20 » Fri Jul 27, 2012 12:31 am
Er.. I thought I knew but maybe I dont!
Can some one pm me too about stopping the key working in the drivers lock! Cheers!!
alzee20
Postby motorman116 » Fri Jul 27, 2012 6:37 am
:D
If you have the blue key fob like I have on my Mk7, then you cant change the batteries, its a sealed unit. The battery inside charges when it is used and charges while the key is in the ignition
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
