Expert help needed 2002 2.0 wont start P1665 P1608 P1664
Re: Expert help needed 2002 2.0 wont start P1665 P1608 P1664
Postby yyahtzee » Wed Feb 27, 2013 2:08 pm
Have a look around this site http://www.remmington.info/ if i were you i would take it off and send it to him or give him a ring
If you need the tools to take the pump off give me a shout i can lend you mine for a small fee plus a refundable deposit.
yyahtzee
Postby fidget » Tue Dec 01, 2015 6:34 pm
have now read through both posts on this issue. and as you said at the beginning of your other thread.
NO ONE PUTS UP WETHER THEY GOT IT GOING AND WhAT IT WAS.!!!
guess I will keep looking... and this is 2 years later.
my advise may not be right, but I like to give my 10p worth, and an answer even if wrong is nice to see.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
5-Speed Manual - MT75
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby jiffyrag » Thu Mar 26, 2020 9:54 am
Just for posterity, as an ametuer with a code 23 problem on my ford transit mk6 I found this thread really useful for checking the wiring coming from the pump.
I only ran into one problem -
'pin 8 of the pump comes out at pin 12 of the computer.'
I think on mine it came out at (roughly) pin 93 or similar (around that area). But other than that it all worked perfectly.
jiffyrag
Postby knobby1 » Sun Jan 03, 2021 8:23 pm
filhyp wrote:hello I discovered your thread and I wanted to know if you found the causes of your failure
This thread was started ~8 years ago so I suspect your request has fallen on deaf ears. The OP hasn't been on this forum since 2014.
Postby mikecurd2005 » Fri Apr 30, 2021 6:59 pm
Anybody else had these codes getting speedo movement looks like its affected by the crank sensor?
mikecurd2005
Postby mikecurd2005 » Fri Apr 30, 2021 7:38 pm
Fixed mine.
Crank sensor white/red goes to 21 on ECU
grey red goes to 22 on ECU.
Wiring loom had been crushed and getting bad signal because of short should of checked it ages ago with the speedo fluctuations live and learn it the signal eemto correct itsself when fired on a bit of fluid.
mikecurd2005
