Mk7 remote key fob programming/pairing
Re: Mk7 remote key fob programming/pairing
Postby loot » Tue Nov 10, 2015 5:08 pm
Yes you did it :-)
At the front you see 040(this means single code for keys so only use the first box code in single)
If you see 044(this means dual code for module initialisation so use both box codes on dual)
:mrgreen:
Ids map here
loot
Postby tibsy » Wed Nov 11, 2015 10:33 am
yes, i was a bit worried in case i f****d up and was left with a van i couldn`t start :oops:
but in the end is was easy peasy!
the "autoprog" page actually tells you about single/dual and which numbers to enter! but in my haste i didn`t notice it at first :)
as always-thanks for your advice :D
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby karltre » Thu Nov 12, 2015 8:59 am
Hi. This key programming is something id like to get to grips with. We have several mk7 transits so it pops up now and again. Im not sure about geeting into the ids system. But from what ive read the turn key 4 times etc doesnt work on mk7?
What about this kind of thing?http://pages.ebay.com/motors/link/?nav= ... 14&alt=web
Is this likely to be a reliable solution?
Cheers
karltre
Postby karltre » Wed Dec 02, 2015 7:21 am
I guess not then
karltre
Postby ake » Wed Dec 02, 2015 8:27 pm
Youd be as well buying an ids setup, then you could code keys, and read fault codes etc
Postby karltre » Thu Dec 03, 2015 8:00 am
I would think the ids is quite a pricey bit of kit? Ive got a couple of code readers for sorting out the simple stuff. The technical stuff goes into a garage (im not a mechanic...just keen to have a go where i can)
But the key issue pops up now and again. So i wondered if that tool might be a good option
karltre
Postby loot » Thu Dec 03, 2015 8:52 am
Food charge 200+ for a new key programmed i think, so if you bought a key fob for 35+ pounds and ids for 100+ pounds then you'd still have change :o
Ids map here
loot
Postby paul2012 » Thu Dec 03, 2015 8:20 pm
loot wrote:Food charge 200+ for a new key programmed i think, so if you bought a key fob for 35+ pounds and ids for 100+ pounds then you'd still have change :o
Or get a new fob. Find someone in here with IDS.
Total price is for the fob & a packet of digestives. :D
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby loot » Thu Dec 03, 2015 9:10 pm
Paul that's ridiculous :?
It's Jaffa cakes :P :lol:
Ids map here
loot
Postby ake » Thu Dec 03, 2015 10:15 pm
loot wrote:Paul that's ridiculous :?
Or any mr Kipling six pack
Postby karltre » Fri Dec 04, 2015 7:45 am
That does look a very good option. I was assuming that the ford ids diagnostics would be a very expensive set up. Possible with software licenses etc.ive done a search since your post. There seems to be a few different one on the market. Any pointer to a good quality one greatly appreciated
Cheers
karltre
Postby loot » Fri Dec 04, 2015 8:52 am
Ids can do anything the dealer does and one use generally pays for it Lol, there are many sellers and it can be hit and miss unfortunately, I've given up on recommending sellers for this reason tho.
Best i can offer is this.
viewtopic.php?f=2&t=156795&hilit=Vcm+sellers+feedback
Ids map here
loot
Postby karltre » Fri Dec 04, 2015 10:10 am
Thanks for all the info. Really appreciated
Ill have a bit if fun no doubt getting to grips with it all
karltre
Postby nick:l » Fri Dec 04, 2015 2:44 pm
Has anyone got access to incodes for post 2010? I'd like to add another remote fob to the van (2012 mk 7) and from autokeyprog i assume it only works to 2010.
The battery broke on the one I have last week and it's been a real pain waiting for a new battery to solder in.
nick:l
Postby loot » Fri Dec 04, 2015 5:36 pm
nick:l wrote:Has anyone got access to incodes for post 2010? I'd like to add another remote fob to the van (2012 mk 7) and from autokeyprog i assume it only works to 2010.
I have no reason to believe that autokeyprog won't code all of them :wink:
Ids map here
loot
