Non starting mk6
Re: Non starting mk6
Postby dirtydog » Mon Jun 29, 2015 8:59 pm
Replaced it and it made no difference so disconnected it again
dirtydog
Postby stephenuk1982 » Mon Jun 29, 2015 9:21 pm
There is a fuse on the positive feed from the battery going down under the drivers seat if that's blown it won't start had it on a mates van around that age
stephenuk1982
Postby paul2012 » Mon Jun 29, 2015 9:48 pm
If new starter motor is just clicking (solenoid)
Then check main barrery terminal on starter if there is 12v+ Should be permanent live, even with ign switched off.
Here's the wiring diagram.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby dirtydog » Tue Jun 30, 2015 2:58 pm
Right have been poking around with my multimeter again, actually had the other half there to help this time.
At the starter motor I'm getting 12v on the big terminal, if I bridge the 2 terminals I still only get a click from it.
Dodgy starter perhaps?
dirtydog
Postby Altransit » Tue Jun 30, 2015 3:09 pm
dirtydog wrote:Right have been poking around with my multimeter again, actually had the other half there to help this time.
Sounds like it, was the old one full of swarf :?:
Postby loot » Tue Jun 30, 2015 3:11 pm
Yes.
Unless the battery hasn't enough power to turn it over but I'd expect it to sound like it wants to, put main beam on and then bridge it, if battery then the lights will go very dim.
:o
Ids map here
loot
Postby dirtydog » Tue Jun 30, 2015 3:12 pm
That's the old one
dirtydog
Postby dirtydog » Tue Jun 30, 2015 3:13 pm
Battery is still at 12.5v
I even tried it with my spare battery which was fully charged
dirtydog
Postby Altransit » Tue Jun 30, 2015 3:14 pm
OK, so it's not the DMF breaking up and clogging the starter, but the new one sounds like it's faulty, assuming all the wiring is now correct :wink: :mrgreen:
Postby dirtydog » Tue Jun 30, 2015 4:24 pm
Replaced the starter again and still the same :(
dirtydog
Postby dirtydog » Tue Jun 30, 2015 4:33 pm
Guess I'm going to have to bite the bullet and get the mechanic to take a look at it
dirtydog
Postby ake » Tue Jun 30, 2015 4:56 pm
Put a jump lead from battery negative to a good earth on engine, then try again
Postby loot » Tue Jun 30, 2015 4:57 pm
Whack the starter :-)
Ids map here
loot
Postby paul2012 » Tue Jun 30, 2015 5:58 pm
New battery, new starter motor, wiring checks out ok....
Have you tried rotating engine by hand to make sure it hasn't seized :?:
paul2012
Postby dirtydog » Tue Jun 30, 2015 6:01 pm
Had it running on sunday
dirtydog
