Mk7 denso injectors
Re: Mk7 denso injectors
Postby karl » Mon Aug 24, 2015 8:52 pm
from reading up on these to get a full picture of these pistons
a believe the 2,2 and the 2.4 are timed differently (the compression stoke )
but am looking for a 115 piston to make things clear
what we need here is a 115/140 ps front wheel drive piston
ive edited it as these will be at mania for everyone to see
karl
Tranny Lover!!!
Postby paul2012 » Mon Aug 24, 2015 10:33 pm
loot wrote:Karl you need to get sizes between 2.2 85 and 2.2 115/140
2.2 and 2.4 will be different sizes. :wink:
There are differnet bottom blocks listed for 2.2 85ps & 115ps
Part no's for 2.2 engines
2006-2011. 6C1Q-6011-AB fit 85ps
2006-2011. 9C1Q-6011-AA fits 85ps with DPF, 110ps, 115ps, 130ps, 135/140ps
2011-2013. BK2Q-6011-CA fits 100ps, 125ps & 155ps (Euro 5)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby loot » Thu Sep 10, 2015 1:23 pm
High quality specialist engineering tools have arrived :-)
Wonder if they'll snap on the first go of undoing the solenoid? :lol:
Ids map here
loot
Postby paul2012 » Thu Sep 10, 2015 2:55 pm
loot wrote:Image
Torque spanners used for tightening 8)
paul2012
Postby loot » Thu Sep 10, 2015 3:21 pm
Certainly are :-)
But i didn't have a 27mm spanner:-(
But i did find an adjustable spanner 8) but the solenoid was barely more than finger tight :shock:
So i stripped a bit more of the injector.
Need to double check this but I'm sure the ball side is meant to face up and not the flat side :? Whether it can move when undoing I'm not sure, otherwise the injectors have been played with before, it would explain why when the 4 were fitted it would start properly and sounded like no exhaust :roll:
Ids map here
loot
Postby karl » Thu Sep 10, 2015 3:30 pm
yep their should be a ball on top of that :) that is what fails on the denso injectors
karl
Tranny Lover!!!
Postby loot » Thu Sep 10, 2015 3:37 pm
It's still in there but the wrong way around.
In the video it explains which way up to have it.
Ids map here
loot
Postby martynx » Mon Sep 14, 2015 3:32 pm
Dont forget the 200 :!: :lol:
Part number -7C16-9K546-AB
Other number - 95000-662
Nozzle Number - DLLA151P955 ( one for Tim to decode :wink: )
Only got snippets of data ( from Panda Diesels machine ) but so far at 1000 microseconds pulse width which is the max their machine tests at there are increased levels for the 200 Injectors compared to the BC type & comparing BC to the lower power AC type , slightly less again.
200 injectors also flow higher in a "midrange" test , (at 800 microseconds) compared to the ones fitted to lesser output models..
The pulse width used in the engine is up to & around 1400 microseconds on all types & is similar across the models so no way of comparing absolute max delivery yet until tested on a rig that can apply 1400 or more microseconds pulse width but looking at the Panda data so far , as expected, a higher power rating per cylinder engines uses injectors that physically produces more fuel..
martynx
Postby loot » Mon Sep 14, 2015 3:52 pm
'Low Flow' injectors have DLLA153P884 Nozzles, these are 7 x 0.12 x 153
'High Flow' injectors have DLLA153P885 Nozzles, these are 7 x 0.15 x 153
Ids map here
loot
Postby dieselhead123 » Mon Sep 14, 2015 8:58 pm
martynx wrote:Dont forget the 200 :!: :lol:
Sorry Martyn, can't find a 'pattern' nozzle cross reference for these, yet :!:
I guess that this suggests that the pattern nozzle manufacturers don't consider there is a large enough market for these.
I will email our supplier the nozzle number and see what they come up with, my pdf catalogue is not necessarily 'up to date'.
However, the '151' part of the code shows that these nozzles do have a 'tighter' spray pattern, allowing for slightly more injection advance to be employed in the fueling map, or the combustion chambers in the 200 pistons have a smaller diameter.
Provided that the 200 nozzles do have a larger cross sectional area than the 'high flow' units they would work well as an 'upgrade' in 4cyl injectors.
Postby Dan T » Tue Sep 15, 2015 11:26 am
2006-2011. 6C1Q-601-A1B fit 85ps
So Why is a service engine listed as the same part number on Ecat ?
All Euro4 2.2's are listed as the same part no's, the only difference being 'New for Old' or 'Reman'.
Not disputing the original pistons possibly being slightly different, just saying ford only list one service engine/short block for the 2.2 Euro 4's.
Dan T
Postby loot » Tue Sep 15, 2015 1:17 pm
Are you saying that the 85ps 2.2 engine is in fact the same engine as the 140 2.2 Dan?
I've read that the 85ps doesn't have oil coolers, could the different numbers be the same engine but with the extra bits or maybe revised numbers?
i think we should all club together and buy 2 broken engines and strip the b*stards down and measure the lot :mrgreen: :lol:
Ids map here
loot
Postby Dan T » Tue Sep 15, 2015 3:47 pm
loot wrote:Are you saying that the 85ps 2.2 engine is in fact the same engine as the 140 2.2 Dan?
Ecat Lists
1596577 / 9C1Q-6011-AA 2.2L from 17-04-2006 (85ps, 110ps, 130ps & 140ps)
If i could remember how to post pics i'd have attached the screenshot.
So Ford Certainly list all 2.2 euro 4 engines with exactly the same part numbers. This is all found using my genuine Ecat subscription, so it's all correct and up-to-date.
Dan T
Postby karl » Tue Sep 15, 2015 3:58 pm
Ecat Lists
hi dan do you have any measurements :!:
surley you would have them needing pistons blocks etc
the 85ps piston ?
edited
also the 140 piston :D
karl
Tranny Lover!!!
Postby Dan T » Tue Sep 15, 2015 5:15 pm
Ecat Lists
the 85ps piston ?
edited
As i already said, I'm not disputing the potential difference in Piston sizes. I don't have any about to measure or we could clear this question up.
I'm only commenting on the fact Ford list all service blocks and Engines as the same part number.
It is possible the original engines were all different, then ford decided to streamline all their service engines to one that suited all... I don't know, but they're listed to suit all now.
Dan T
