Mk7 2.2 85ps ticking/knocking
Re: Mk7 2.2 85ps ticking/knocking
Postby Thequeenscheese » Sun Aug 13, 2017 3:43 pm
The link I posted int alternator if you didn't read it, it was the injector pipe I think sucking air
2.2 tdci T280
Thequeenscheese
Postby tjm07 » Sun Aug 13, 2017 4:14 pm
Thanks again, I did have a read and will have a good root around at my next opportunity
2008 Mk7 Swb transit crew bus 85ps
2002 BMW 320d e46 204k and counting SCRAPPED
2005 Vauxhall astra sri SOLD
2005 BMW 320i m sport
2006 Vauxhall Astra 1.4 affectionately nicknamed s#*tbox
tjm07
Postby paul2012 » Sun Aug 13, 2017 7:28 pm
tjm07 wrote:So bore has been measured and is 0.08mm larger than the smallest bore of 86mm. So I have cylinder 1 at 86.01, 2 at 86, 3 at 86.02 and 4 at 86.08, I had equal compression after the first assembly, so unless anyone advises against I am going to re-assemble, and then try and move injector 4 to a different cylinder (have f-super) and see if the noise goes with it? Advice/thoughts welcomed
Cylinder 4 is beyond tolerance a7 86.08
Ford specs
Cylinder bore diameter Class A - 86.00 - 86.01
Cylinder bore diameter Class B - 86.01 - 86.02
Cylinder bore diameter Class C - 86.02 - 86.03
Your engine vid some very similar to this P8FA engine I had here (cracked/melted piston at cylinder 4) :arrow: https://www.youtube.com/watch?v=ePTvmrRIP40
Sadly. Engine was beyond repair. even with a rebore to .5 oversize.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby tjm07 » Sun Aug 13, 2017 7:45 pm
Paul2012 appreciate your response, so do you think that with a leak down test I would see the dipstick tube pressurised? Showing leakage passed the rings due to being oversized? I know you have done many conversions to the 130ps mondeo engine, could you list all things I would need to get from where I am now to a running van please
tjm07
Postby tjm07 » Tue Aug 15, 2017 6:06 pm
Looking for any info anyone has on the 130ps Mondeo engine swap i know paul2012 is the man and will eagerly await his reply, if anyone else has any information it will be greatly received to enable me to try and source and price parts to be able to make an informed decision, thank you in advance
tjm07
Postby karl » Tue Aug 15, 2017 6:11 pm
tjm07 wrote:Looking for any info anyone has on the 130ps Mondeo engine swap i know paul2012 is the man and will eagerly await his reply, if anyone else has any information it will be greatly received to enable me to try and source and price parts to be able to make an informed decision, thank you in advance
Complete car any good to you :?:
karl
Tranny Lover!!!
Postby tjm07 » Tue Aug 15, 2017 6:21 pm
I think you are a bit far from me, I'm in east Kent, your profile says Manchester? Got a few breakers near me, I'm hoping I can get a list together and get a job lot. Thanks for the offer though
tjm07
Postby karl » Tue Aug 15, 2017 7:04 pm
tjm07 wrote:I think you are a bit far from me, I'm in east Kent, your profile says Manchester? Got a few breakers near me, I'm hoping I can get a list together and get a job lot. Thanks for the offer though
£400
Give me a shout if you want it
100,000 on cloçk genuine miles and hasn't moved since last mot
karl
Tranny Lover!!!
Postby tjm07 » Tue Aug 15, 2017 7:28 pm
£400
I'll bear it in mind, thanks
tjm07
Postby tjm07 » Sun Aug 20, 2017 5:48 pm
Engine is back out again, for the last time......? The deeper in I get I feel i have made the right choice, the mountings on the ECU are not done up?? That's the trouble with not having any history with van, but can't complain for what I gave for it. Got plenty off feelers out for the parts I need, should start hearing back tomorrow hopefully
tjm07
Postby bambi mk 1 » Sun Aug 20, 2017 9:33 pm
You can bore the bad cyl and fit a liner and put it back to std :wink:
bambi mk 1
Postby tjm07 » Tue Aug 29, 2017 12:09 pm
Just want to be sure before i buy, the jag engine is still good for the 2.0 tdci conversion, I'm sure it is just want reassurance the sticker on timing chain case says duratorque x400 130ps. Thanks in advance
tjm07
Postby tjm07 » Tue Aug 29, 2017 5:48 pm
Just spotted this on eBay https://www.ebay.co.uk/itm/152674747823, gutted, I've just bought and paid for an engine, bit far away from me anyway but might do someone else on here a turn?
tjm07
Postby knobby1 » Wed Aug 30, 2017 1:32 am
Um....the one shown is a 125ps 2.0L TDCi out of a Mk6 if memory serves....no good for a Mk7 2.2 FWD.
Postby tjm07 » Wed Aug 30, 2017 4:57 am
Knobby- it's not a direct replacement but for someone that wants to do a conversion it's ideal as it comes with wiring looms, pcm, keys etc etc.
tjm07
