I hope you dont mind me posting on your thread crossfirerob but simwasere is helping out no end on this thread so ill post here for time being.
When the van is ticking over on petrol, there is a slight misfire (not under load) vacuum reading is good and steady at 21 inch/mercury? So I believe there is no vacuum leaks on intake manifold. Ive replaced the plugs for NGK Irodium, New coil packs, new ignition leads, new lambda oxygen sensor (pre-cat), cleaned MAF sensor. No fault codes being stored on petrol ECU.
When the engine is switched to gas there is a distinct misfire throughout the rev range which shakes the engine irratically which make it undrivable. The coolant system is full and the vapouriser is hot to touch. Also the van switches from petrol to gas no problems so the temp sensor on vapouriser must be reaching is 32 degree setting as the system switches over to gas no problems. Ive also kinked the gas feeds one at a time and each one makes the engine run erratically equally the same so i believe its not a problem with one particular injector. The problem must be across all injectors. Does this point to a blocked filter/distributor?
Ive checked the throttle position sensor for resistance readings and its 0.77 ohms between middle pin and outside pin at idle which rises to 3.71 Ohms at full throttle and is consistant all the way through.
If I need to take the distributor off to service/clean it. Can i just dosconnect the gas pipes from it or will the gas leak out everywhere?
I know some of my questions may be amaturish but ive never worked with LPG system before however I have rebuilt engines before so am reasonably competant to do this. Any advice appreciated and if anything ive said above is wrong please say so as im always willing to learn.
Thanks again
Matt
