DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby andrusl » Mon Apr 15, 2013 9:44 am
WF0VXXBDFV1K05011 cheers[/quote]
Transit 2000-2006, 2.0L Duratorq DI (75PS), Moondust Silver (Metallic)
VIN Number: WF0VXXBDFV1K05011
Registration information for your currently selected Vehicle:
First Registration Date:
Registration Number: Registration Date: Registration Country: Modified Date:
Historic Registration Dates:
Primary Features
Build Date: 24.10.2001
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 300S Series
Engine: 2.0L Duratorq DI (75PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Moondust Silver (Metallic[/quote]
MINOR FEATURE CODES
With Low Roof
With Rear Mudflaps
With Front Mudflaps
With Full Partition - Steel
LH Sliding Side Cargo Door - Low
With Hinged Rear Loading Doors
Southampton Plant Built
Special Order Paint
With SVO Application/Label
Marketing Level 3
With Rear Blanking Panel
Less Heated Rear Window
Less Header Mounted Package Tray
With Complete Rear Hardboard Trim
With Partial Headlining - Moulded
With Roof Height Feature Pack 1
With Door Map Pocket
With Front Roof Grab Handle
With Load Space Tie Down Loop
With Cargo Stowage Rail (Mid)
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
With Rear Step - Centre
Less Rear View Mirror
Large Head/Short Arm Mirror
Passenger Lrg Head/Short Arm Mirror
Less Trailer Towing Attachments
Fleet Key
With Door Dead Locks
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
With Grey Plastic Rear Bumper
With Driver Air Bag
With Spare Tyre Security Package
195/70R 15C LI 104/102 BSW
Any Brand Tyre Vendor
Less Engine RPM Control
Cold Start -15 Deg C
4 Wheel Anti-Lock Braking System
With Brake Only Traction Control
With Manual Clutch
Less Rear Seat Climate Control
With Pollen Filter
With Recirculating Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
With Anti-Theft Alarm
Standard Duty Battery
Drivers Seat Rechargeable Battery
With Radio Pre-Equipment Pack 1
2000NT Series
With Power Point Plug
With Load Compartment Lamp
Less High Mounted Stop Lamp
With Manual Headlamp Levelling
With Battery Cut Off Relay
With Auxiliary 6 Fuse Box
andrusl
Postby guystransit » Mon Apr 15, 2013 9:22 pm
thanks again andrusl ... does not mention my grey leather seats (maybe fancy vinyl ) :lol: and the rear step is still intact after all these years :shock:
guystransit
etis
Postby bigjay123 » Wed Apr 17, 2013 10:20 pm
can someone run my van through etis please s979jfp
bigjay123
Re: etis
Postby fedup2 » Wed Apr 17, 2013 10:37 pm
Done :)
Launch x431 owner ;)
fedup2
Re: etis
Postby fedup2 » Wed Apr 17, 2013 10:38 pm
fedup2
Postby bigjay123 » Thu Apr 18, 2013 11:31 am
hey can you run my van through etis plz s979jfp
thanks jay
bigjay123
Postby JoeySully » Thu Apr 18, 2013 1:36 pm
Hello
Can you find me my vans details too please ?
Reg is P990SHG
Joe
Transit 1997, MK5 Diesel 2.5T (100PS) High Roof Camper
JoeySully
Postby blue estate » Thu Apr 18, 2013 2:05 pm
bigjay123 wrote:hey can you run my van through etis plz s979jfp
thanks jay
We are sorry, but no information could be found for the VIN/Registration number you entered - S979JFP
Click here to check and re-enter the information you supplied.
blue estate
JoeySully wrote:Hello
Reg is P990SHG
Joe
Transit 1995-2000, 2.5L Diesel T (100PS), Diamond White 73
VIN Number: SFALXXBDVLTD95398
Registration Number: P990SHG
First Registration Date: 11.02.1997
Registration Country: GB
P990SHG 11.02.1997 GB
18.01.2012
18.01.2012
Primary Features
Build Date: 27.06.1996
Vehicle Line: Transit 1995-2000
Series: 190L
Engine: 2.5L Diesel T (100PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.14
Emission: 95 EEC Light Duty Truck
Territory: (+)"GB"
Paint: Diamond White 73
Interior Fabric: G-C Camelot
blue estate
Postby JoeySully » Thu Apr 18, 2013 2:53 pm
Thank you Blue Estate,
would it be possible to get the "MINOR FEATURE CODES" as well ?
Joe
JoeySully
Postby blue estate » Thu Apr 18, 2013 2:57 pm
JoeySully wrote:Thank you Blue Estate,
Joe
No that's all it lists :(
blue estate
Postby JoeySully » Thu Apr 18, 2013 3:44 pm
Joe
OK No Problem
Thank you anyway :)
JoeySully
Postby andrusl » Thu Apr 18, 2013 7:00 pm
Joe
OK No Problem
Thank you anyway :)
I can check the minor features tomorrow ;)
andrusl
Postby andrusl » Fri Apr 19, 2013 8:59 am
Joe
MINOR FEATURE CODES
With Rear Mudflaps
With Front Mudflaps
With 180° Cargo Door Check Arms
With Smoke Compliance Label
With Tool Kit
With Manual Front Windows
With Clear Glass - Complete
With Laminated Windscreen
I/P Pull Out Cup Holder
With Sunvisor Mirror - Passenger
With Engine Compartment Noise Pack
With Engine Dash Insulator
With Insulator
With Wide Body Moulding
With Fixed Front Passenger Seat
With Front 2 Way Headrest
With Rear Tow Hooks
Mid Grey Front Bumper
With Driver Air Bag
With Passenger Air Bag
Tyre Carrier Drop-Dr Open
With Exterior Tyre Carrier
With Steel Spare Wheel
With Argent Wheel Finish
With Standard Tyre Tread - Front
With Standard Tyre Tread - Rear
With Full Wheel Cover
'CAV' Fuel Injection - Electronic
With High Centre Of Gravity Pack
Front Axle Rating-Normal
With Standard Duty Rr Leaf Springs
Rear Axle Less Limited Slip Diff
With Salisbury Axle
Type 51 Rear Axle 3850lb(1750 Kg)
With Straight Rear Exhaust Exit
With Handbrake Boot
With Diagonal Split Braking System
With Sngle.L/B Dvr/Dual L/B Pass.St
With Plastic Fuel Tank
With Power Steering(Fixed Ratio)
With Tachometer
With Analogue Clock
Heavy Duty Battery
With Cigar Lighter
andrusl
Postby JoeySully » Fri Apr 19, 2013 9:11 am
Excellent. Thank you for that.
Joe
JoeySully
Users browsing this forum: Bing [Bot], Google [Bot]
