how to bypass a mk7 egr valve?
Re: how to bypass a mk7 egr valve?
Postby winterheating » Sat Feb 20, 2010 12:47 pm
whats the easiest way to get pics from an iphone to here :?:
winterheating
Postby winterheating » Sat Feb 20, 2010 1:08 pm
just need someone to try it on a mk7 now :?:
winterheating
Postby winterheating » Sat Feb 20, 2010 1:18 pm
marked part on left is were ive used the engine breather connection to intake to connect new EGR pipe.
the marked part on right is were ive cut the metal pipe normally going to rear of engine to attach to exhaust manifold(allready blanked exhaust mjanifold) and joined the air intake pipe to a rubber hose then joined to this metal pipe.
winterheating
Postby ake » Sat Feb 20, 2010 3:49 pm
Explain it in words of one sylable and I'll try it on my mk7
Postby Lemonade » Sat Feb 20, 2010 8:11 pm
Does anyone know if the EGR valve is supposed to make any noises etc as ever since new mine has made a slight
scuffing noise at low speed shortly after changing gear from 1st to 2nd. Apart from this everything seems OK and
the van runs well. The noise is however eliminated if the multiplug to the EGR valve is disconnected.
Lemonade
Sportvan Owner!
Sportvan Owner!
Postby vanhire » Sat Feb 20, 2010 8:35 pm
the only noise the valve makes is on the self clean cycle when you switch off the ignition,could have a fault with the motor in the valve?
vanhire
Postby winterheating » Sun Feb 21, 2010 12:41 am
ake wrote:Explain it in words of one sylable and I'll try it on my mk7
im not sure on the layout of the mk7.
but basically the exhaust pipe to egr valve needs blanking at exhaust manifold, then this pipe needs connecting to the air intake before turbo but after MAF and thats it.
ive used the engine breather pipe, but after a short time today the crankcase pressure got too high and started to pass oil past injector oil seals, as the engine breather needs to have suction from the intake pipe.
so i tee'd in that pipe again and all has been fine allday :D no light no loss of power/boost no smoke no hessitance. :D
winterheating
Postby ake » Sun Feb 21, 2010 12:24 pm
Right I'll have a look at dinner time tomorrow and see whats what :)
Postby winterheating » Sat Feb 27, 2010 1:35 am
ake wrote:Right I'll have a look at dinner time tomorrow and see whats what :)
which dinnertime was it :?: :lol:
winterheating
Postby ake » Sat Feb 27, 2010 10:25 am
Don't :evil: Had a hard week, 100 mile detour to get home on thursday, and last night van came home on recovery with dead alternator (4000 miles old) and flat battery :( :( :( Will get a proper look and some pics when I get it back
Postby winterheating » Sat Feb 27, 2010 11:59 am
does yours have 2 batteries :?:
winterheating
Postby ake » Sat Feb 27, 2010 4:47 pm
No :(
Postby winterheating » Mon Mar 01, 2010 9:45 pm
id put it on hold for now :!: :!: ,
my car has started to show signs off high crankcase pressure again, i'll have to to it routing it after the turbo, but so that theres still a difference in boost level so that it will still circulate.
winterheating
Postby ake » Mon Mar 01, 2010 9:51 pm
Ok mate, let me know :)
Postby Guy88 » Mon Mar 29, 2010 2:08 pm
are we any further on this?
iv been thinking about this and all i can see is that it needs the exhaust side blanked and the inlet side routed to the air filter, from wat i can tell is on boost it should be closed anyway :?: :?: :?:
so wat i was thinking is disconnect and blank the exhaust side
route the inlet side to the air filter and possibly fit a one way valve to it to only allow air in rather than boost out :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
